Morgan Aero 8
5 members (ChrisConvertible, John V6, Mats, Alan Patterson, flyfisher), 327 guests, and 44 robots.
+8Rich 101
John V6 65
Suspension upgrades
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,918
Posts838,263
Smed., Spanner Juggler
Page 1 of 4 1 2 3 4
#79098 15/01/12 03:00 PM
Viper Offline OP
Sir S1'a'lot
Sir S1'a'lot
My speedo is over reading by at least 10% which also means the recorded 2200 miles should only be 2000.
Anyone else had this and is there a remedy?
2002 Aero 8 S1
2023 Plus 4 (woman’s)
Don't know about the electronic ones, but in the days of mechanical speedometers, the speed reading and mileage recorder were two separate items - so your mileometer may be correct...
Cheers,
Hi Viper, I found the web site 'Morganatica' through another thread on TalkMorgan. Go to section 6, section Instrumentation.
That may help.
Ian
When I had my diff upgrade, Ben at Mike Duncan's showed me have to adjust the later speedos. Looked pretty straightforward apart from working out the correct value to input! Anyone know what the figures actually represent?
le Asbo du Bling
le Asbo du Bling
I think you'll find this is the case for most speedo's when compared to Satnav's. My guess is that this gives the car manufactures enough wriggle room if deluged by speeding claims.
Image the situation if it under reported by 10%. cop
Somewhere on the forum ( along while ago) someone did have a fix for this as they had changed the diff and it involved resetting or selecting a value on the speedo. I cant find the post but maybe Simon can help.
Slowly going green
Viper Offline OP
Sir S1'a'lot
Sir S1'a'lot
Thanks Guys....I'll check out section 6.
Trouble is at 200mph I'm really only doing 180mph.....so annoying smile
I know most cars over read but I've never seen 10%. Porsche are usually spot on.
I'm sure if its over reading then the milometer must be doing the same???
2002 Aero 8 S1
Viper Offline OP
Sir S1'a'lot
Sir S1'a'lot
Actually what/where is section 6??
2002 Aero 8 S1
Speedo cannot legally read low and has a 10%(I think) allowance for over stating speed.
This is the reg for when testing a kitcar at its LVA so I assume it applies to all cars.
Does the MOT include a test?
I don't recall seeing one. Maybe its just a yes/no for is it working?
"Actually what/where is section 6??".
Viper,
Section 6 is within a wikipedia type website.
Type Morganatica, in Google and then look at section 6.
Ian
Smile, it confuses them
From memory I believe the legally acceptable region for a speedo from a manufacturer is +10% (Showing 77 in a 70) and -3% (Showing 68)
Wheel and tyre combinations can cause a significant margin on this.
Page 1 of 4 1 2 3 4
