7 members (Stevo666, Burgundymog, John Winn, +8Rich, verysideways, Tony Quinn, TBM),
288
42
Posts837,994
Posts: 14 Likes: 1
Posts: 14 Likes: 1 |
Hi, can anyone recommend a Morgan specialist or other garage which is able to refurbish the starter motor and solenoid on my 1984 Morgan 4/4 in Cornwall. Thanks
Posts: 6,675 Likes: 441
Posts: 6,675 Likes: 441 |
Perranwell are near Truro, but you've got the Ford CVH motor in, so the starter/solenoid are pretty standard fare and most motor factors could get you a replacement one. If you do want to refurb, google 'starter motor repair Cornwall' and it will bring up several options.
Posts: 14 Likes: 1
Ideal ... many thanks TBM...good advice!
Posts: 14 Likes: 1
It's actually got a Fiat 2L engine. Would the starter/solenoid be the same as a Ford CVH?
Ah, no, it will be different, but still fairly easy to get hold of a recon.
Posts: 8,696 Likes: 416
Posts: 8,696 Likes: 416 |
I believe the 2 litre Lampredi engine you have was used in a variety of Fiat and Lancia cars of the era. It might be just as cheap to buy a new or exchange starter as plenty seem economically available online. Check here for full listing of cars that used the 2 litre variant of this engine.
Just did a search, and you've asked the question on here before - the Fiat 131 was suggested as a likely source.
However if you whip it off and take it to a 'rewinders' they should sort it. The solenoid is attached to the body of the starter..
Posts: 3,826 Likes: 69
Posts: 3,826 Likes: 69 |
Just to add that if it is the 2 litre fiat engine (and what a brilliant engine that is) then you have a plus 4 not a 4/4
Here's a good list of all cars that use the Lampredi for cross referencing parts..... Fiat Twin Cam
Imagine the supercharged 2.1 litre version of that engine with half the number of cylinders but heading towards twice the horsepower of the Morgan V8, in the early 80's
