1 members (+8Rich),
352
93
Topics49,869
Posts837,666
Posts: 19 |
The press release for the new Super 3 mentions " the bevel box has been re-engineeered using a custom tooth profile." I presume this has been done to solve the noise of the ones fitted to the old three wheeler & if so wonder if it would it be possible to fit one to replace the screamer in my 2015 M3W. Comments please. Ken Jones
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
The bevel box in the Super 3 was said at the launch to be interchangeable with the Quaife version. It certainly looked the same externally with the same mounting points.
Posts: 8,684 Likes: 413
Posts: 8,684 Likes: 413 |
I was just weighing up the BB drive ratio. I suppose the extra revs and power available from Ford engine would align nicely with the higher quoted top speed, given same gearbox and drive ratio. Note sure of Super 3 rear tyre circumference though.
I was just weighing up the BB drive ratio. I suppose the extra revs and power available from Ford engine would align nicely with the higher quoted top speed, given same gearbox and drive ratio. Note sure of Super 3 rear tyre circumference though. Rear tyre is 195/65/15
Thanks Rog. So 4% larger circumference. Close enough I suppose and making the Super 3 suitably long-legged with same BB ratio.
Posts: 423 Likes: 2
Posts: 423 Likes: 2 |
Thanks Rog. So 4% larger circumference. Close enough I suppose and making the Super 3 suitably long-legged with same BB ratio. Assumes the drive pulley on the rear wheel is the same size as the M3W
Lance 1981 Plus 8 2016 Three Wheeler 2022 Corvette Stingray Convertible z51
Posts: 33 |
I'd think the biggest question mark is the new transmission ratios.
Noah
Posts: 19 |
A bit of thread resurrection. My 2017 car has a real screamer and I want to do something about it. Have investigated a few options but not much out there. Is there any more information available about retro fitting a new bevel box from a Super3?
A bit of thread resurrection. My 2017 car has a real screamer and I want to do something about it. Have investigated a few options but not much out there. Is there any more information available about retro fitting a new bevel box from a Super3? Billy Bellinger has a solution for reworking the bevel box, which quietens it. https://jb-engineering.co.uk/?page_id=65Vm
Posts: 19 |
Thank you That is a good steer. I will check that out.
