7 members (DaveW, +8Rich, nestor59310, TalkMorgan, RedThree, RubyMog95, MartinB60),
308
57
Posts837,271
Posts: 6,666 Likes: 433
Posts: 6,666 Likes: 433 |
Or use the hyperlink function on the site Click here
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
Your version didnt work... nor did the tinyurl I created! Something odd on the ali website? https://www.aliexpress.com/item/1005003305400563.html should work...
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
Strange, my long address, TBM's and Paul's short version all work for me. Sorry Bitsobrits but your short version just took me to a general cover page rather than the item.
Ian, would you be able to put Paul's version in the Alt Parts List?
Red Leader
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
I have added the link to the latest amendment to the Alternative Parts List that should be available in the next few days, on the link at the top of this forum. The part number to search for is PF4C/00, it's available from other suppliers as well, at least in theory.
A PF3C/00 will physically fit, seems to be more available and will probably be usable if that is all you can get. The voltage/throttle profile is slightly different, it's used on Ducati engines. Some Ducati owners have fitted the PF4C/00 and say it makes little difference, so it may be the same the other way around? It would be useful to know if they are interchangeable in operation as well as fitment if anyone has used a PF3C/00.
Posts: 360 Likes: 36
Posts: 360 Likes: 36 |
Just be aware that the TPS voltage setting can be anywhere from .27v to .47v - if you do not get it correctly set then a MIL light will come up and sometimes the idle can become uneven. as the TPS setting will also affect the idle control valve operation.
Posts: 1,737 Likes: 55
Posts: 1,737 Likes: 55 |
A PF3C/00 will physically fit, seems to be more available and will probably be usable if that is all you can get. The voltage/throttle profile is slightly different, it's used on Ducati engines. Some Ducati owners have fitted the PF4C/00 and say it makes little difference, so it may be the same the other way around? It would be useful to know if they are interchangeable in operation as well as fitment if anyone has used a PF3C/00. Thread drift alert: Does anyone know what the (non-adjustable) TPS fitted to later cars is? PF1C/00?
Andy
Posts: 807 Likes: 38
Posts: 807 Likes: 38 |
test linkHmm...didn't know there was a link utility here, but found it. Thanks for the tip.
Steve Late 2012 M3W
Or use the hyperlink function on the site Click hereThanks, I didn/t know about that - every day is a schoolday
Red Leader
1 member likes this:
TBM |
So I tried to change the TPS today and it does need a T17 Torx which is virtually unobtainable! Also the mounting screws have been mangled so it either left the factory like that or done during servicing....... I've also found the fuel lines to the injectors are cracked  ![[Linked Image]](https://www.tm-img.com/images/2024/03/16/IMG_0103.jpeg)
Red Leader
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
Why isn't anything straight forward anymore.
