6 members (Alistair, jbk, RichardV6, Gordon D, bmgermany, MartinB60), 159 guests, and 49 robots.
+8Rich 87
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,354
Christoph
TBM Offline
Or use the hyperlink function on the site Click here
Originally Posted by Bitsobrits
Chris-have a look at this site to help you reduce crazy long URLs: https://tinyurl.com
for example, I copied your link and turned it into: http://tinyurl.com/TPSensor
Your version didnt work... nor did the tinyurl I created! Something odd on the ali website?
https://www.aliexpress.com/item/1005003305400563.html should work...
Strange, my long address, TBM's and Paul's short version all work for me. Sorry Bitsobrits but your short version just took me to a general cover page rather than the item.
Ian, would you be able to put Paul's version in the Alt Parts List?
Red Leader drive
I have added the link to the latest amendment to the Alternative Parts List that should be available in the next few days, on the link at the top of this forum. The part number to search for is PF4C/00, it's available from other suppliers as well, at least in theory.
A PF3C/00 will physically fit, seems to be more available and will probably be usable if that is all you can get. The voltage/throttle profile is slightly different, it's used on Ducati engines. Some Ducati owners have fitted the PF4C/00 and say it makes little difference, so it may be the same the other way around? It would be useful to know if they are interchangeable in operation as well as fitment if anyone has used a PF3C/00.
Just be aware that the TPS voltage setting can be anywhere from .27v to .47v - if you do not get it correctly set then a MIL light will come up and sometimes the idle can become uneven. as the TPS setting will also affect the idle control valve operation.
Thread drift alert: Does anyone know what the (non-adjustable) TPS fitted to later cars is? PF1C/00?
Andy
test link
Hmm...didn't know there was a link utility here, but found it. Thanks for the tip.
Late 2012 M3W
Thanks, I didn/t know about that - every day is a schoolday smile
Red Leader drive
1 member likes this: TBM
So I tried to change the TPS today and it does need a T17 Torx which is virtually unobtainable! Also the mounting screws have been mangled so it either left the factory like that or done during servicing.......
I've also found the fuel lines to the injectors are cracked frown
Red Leader drive
Why isn't anything straight forward anymore.
