4 members (moggywills, SwissMogFan, RedThree, JMcL), 195 guests, and 65 robots.
+8Rich 83
Luddite 50
Posts837,946
SCX358G Offline OP
I have just bought a Bosch 049 battery to replace the battery in my Plus 8. This is a 45AH battery rated at 330 cranking Amps.
I put a battery tester on it and go the following:
Charge 100%. 12.82V
Health 78%. CCA 292A
Internal R. 10.27 milliOhm
I've no idea how the tester works, but I would speculate it infers the state of charge from the open circuit voltage (12.82V) and it measures the internal resistance by putting the battery briefly under load (maybe 100A ?). No idea how it measures the CCA. Nor any idea of how the health number is calculated.
But anyway, 10 milliOhms seems a bit high for a brand new battery. I've seen values of 5-8 millOhms for other new batteries of similar size and technology.
Does anyone know anything about what is an acceptable. value for internal resistance of such batteries?
I don't see a date of manufacture on it, so I've no idea how long it has been sitting in store, so I'm wondering if the battery has simply degraded over time before I got it.
Dave
Typically the old style battery "testers" with the sharp prongs to interface with lead terminals take a current draw in the high hundreds or thousands of amps for a second or two, whilst indicating the current through a robust low resistance. This may prove the CCA (a laboratory figure in any case) but probably takes a lump out of a new batteries life.
Low internal resistance indicates a batteries ability to deliver high currents so is important for a starter battery but its not a figure that's often used. For longevity battery capacity measured in amp hours (Ah) is the best guide. High capacity means a) an easy starting car puts little percentage drain on it, and b) as capacity naturally reduces with age you have a usable capacity left for longer.
My Roadster is factory fitted with a generic type 075 battery with C20 rate capacity of 60Ah meaning it should provide when new 3 amps for 20 hours.
45Ah sounds a little low for such an engine but it may be you don't have space for larger capacity. As a rule I would always fit the largest capacity that can physically be accomodated. The price not being proportionate.
1 member likes this: Taffmog
SCX358G Offline OP
Dave
After trouble with a new Battery fitted in the UK -and suitable for a Bambina, I fitted an Enersys Odyssey PC925 in my plus 8, had to make a modified bracket to fitted it lying down aft on the driver side where the original was . These AGM units really kick the rover over starting immediately always . I put a Ctek on it once a month if I have not been out driving and very happy. I guess thats why the Aussie supercars etc use them in their race cars.
99 plus 8 indigo
I suspect some of that "internal resistance" may also be in the connection to the battery.
Dave, the date stamp is part of a code usually hot stamped in a sort of dot matrix format on the top blue plastic casing
Oh, just found this helpful guide
Back in the day before the common adoption of sealed lead calcium batteries we stocked and supplied, often via mail order, dry charged lead/acid motorcycle batteries, allowing a long shelf life. This avoided transport issues with acid content. Customers were advised to fill with battery acid readily available at most tyre dealers. We did keep a carboy of dilute acid for counter sales though.
