5 members (mph, Robbie, Dougie, BLUE+4, JohnHarris), 225 guests, and 62 robots.
+8Rich 78
Topics49,871
Posts837,677
Rudolf
lez #770248 01/03/23 10:22 AM
Sounds to me like it might have been the mating surface on the stub axle that was at fault rather than the discs themselves?
I can't remember why, but I removed my discs about 15 years ago and when I replaced them I had a dreadful pulsing through the brake pedal as if the discs were warped. Double-checked the mounting and somehow I'd managed to trap a tiny bit of debris between the disc and stub axle mounting faces. Cleaned them up and flatted them off with a bit of emery cloth and some engineer's blue, reassembled and they've been perfect ever since.
lez #770257 01/03/23 03:13 PM
I had new disks on my 4/4 last year. The garage warned me to gently bed them in & to slowly build up the heat (harder braking) over a matter of weeks, or they would warp. Apparently for track work, they only use pre bedded in disks.
lez #770272 01/03/23 05:48 PM
I was told a long time ago that new discs were heat treated before final grinding, which reduced warp in use. I was also told that this is no longer the norm.
lez #770330 01/03/23 11:40 PM
I have access to a Colchester Mastiff lathe.
Can skim a complete brake disc in one operation, without removing it from the hub!
Arwyn
lez #770938 09/03/23 10:22 AM
I've replaced my 2011 Plus 4 standard set up (pre industrial revolution Austin Westminster or something similar) with Mulberry brake kit which is all Hi-spec parts, about 8 years ago. The calipers are 4-pot and the discs/bells are 2 piece. The discs are 312mm diameter if I recall, and with Mintex MGB522 pads give a lovely feel under foot and great stopping power. I did buy a spare set of discs for future, which will of course bolt onto the existing bells, but this shouldnt be for a while given summer use and almost sensible driving. After 20k there's no lip on the discs and the pads are bearly worn. I remove the pads, clean and grease every 2 years. After driving my Exige with AP Racing 4-pot set up I didn't feel the standard offering from Morgan was upto spec.
lez #793737 12/01/24 07:46 PM
Any one know the pat number for the brake discs used on 1984 4/4 trying to sorce at motor factors were they off some other cars?
lez #793738 12/01/24 08:21 PM
TBM Offline
I stand to be corrected, but when I was making enquiries for my 1972 I was lead to believe they were unique to Mog and hence subject to the usual Morgan Mark Up pricing.
Gareth hare #793741 12/01/24 10:10 PM
Morgan specific I'm afraid.
Arwyn
lez #793752 13/01/24 09:27 AM
Cain at Wolf Performance sells them
lez #793772 13/01/24 03:18 PM
You could also try Terry Foxen at G.E.E Gigg Mill • giggmill@hotmail.com.
https://geeltd.co.uk/gee/
He is on the mend and getting about again.
06 Saab 93
