0 members (), 330 guests, and 36 robots.
+8Rich 94
Posts837,276
#794327 22/01/24 03:50 PM
I'm in the process of rebuilding the calipers on our '64 4/4. The pistons have been removed, everything has been cleaned and I'm ready to reassemble. Is there a grease recommended for the new seals in order to get the pistons back in, or should I just use brake fluid. The only grease that I can find that specifically mentions "caliper assembly" is silicone based, and I'm using a DOT4, non-silicone fluid. Any advice is appreciated.
I use brake fluid, always works for me.
Cheers
John.
1 member likes this: 1854sailor
Cheers
John.
Thank you!
I prefer to use Red Rubber Grease as brake fluid is nasty stuff and has a habit of pinging a tiny splash into your eyes as you wriggle seals back together
+1 for red rubber grease, Ive used it in the hydraulic industry for years.
David Byrne
