Posts837,284
Posts: 460 Likes: 80
Posts: 460 Likes: 80 |
I'm in the process of rebuilding the calipers on our '64 4/4. The pistons have been removed, everything has been cleaned and I'm ready to reassemble. Is there a grease recommended for the new seals in order to get the pistons back in, or should I just use brake fluid. The only grease that I can find that specifically mentions "caliper assembly" is silicone based, and I'm using a DOT4, non-silicone fluid. Any advice is appreciated.
Posts: 614 Likes: 22
Posts: 614 Likes: 22 |
I use brake fluid, always works for me. Cheers John.
1 member likes this:
1854sailor |
I use brake fluid, always works for me. Cheers John. Thank you!
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
I prefer to use Red Rubber Grease as brake fluid is nasty stuff and has a habit of pinging a tiny splash into your eyes as you wriggle seals back together
Posts: 513 Likes: 56
Posts: 513 Likes: 56 |
+1 for red rubber grease, Ive used it in the hydraulic industry for years.
David Byrne
