5 members (Morganmike, B3MOG, JohnHarris, Mogdavid, teknome), 145 guests, and 16 robots.
+8Rich 103
John V6 66
Factory meet
Diss Festival of Transport
Goodwood
My 4/4 as it was in 1975
US Cars - Metric Threads?
by Paul F - 17/09/26 08:29 PM
Nice hardtop
First Morgan as it is now
by Strathaven, September 15
Topics49,931
Posts838,506
AlexCreasey
TBM Offline
Looks similar to the one in my MGB? Depending on what the rotor looks like inside, I'm sure one could be made to fit.
Fan's about £60 and rotor is around £10
TBM Offline
And you can find cheaper than that and with a choice of CFM. (flow rates) Choices are only limited if you stick within the limitations of the Morgan world.
More than the cost saving, such things are simple and fun. My first priority is quality parts, second is improving my mogs and only last do I worry about price.
You would be surprised how many times that turns out to save money! .
You got the idea! Of course, both the rotor and the CFM shoulkd be considered..perhaps from different sources. I long ago (300,000 kms) learned that the
only thing I can be sure of with a failed or failing component is that if I replace same with same, it will fail again.[ Do you have other wishes for your heating
system like a three fan positions rather than two? Just beware if you buy a fan from one place and a motor from another you might be disappointed that the
don't fit together without "encouragement" But at normal prices of these thingies,what is the risk?
Peter Morgan once wrote me that he gave all buyers a "start". It was for each of us to finish the job as we wished.
gmg
Hi All,
So to update you I bit the bullet and thought I would try the MGB heater motto below £85 as a replacement for the £380 +VAT KL one from Morgan
https://www.mgocspares.co.uk/produc...large-impellor-kit?nodePath=1/3/4/18/650
This fitted well provided I used 10mm spacers and sealant.
So a good option for others if the KL isn’t available or out of budget
Will update with some better pictures
Many thanks
Will
1 member likes this: RichardV6
