1 members (JoeSpeetjens), 295 guests, and 36 robots.
+8Rich 94
Posts837,276
BobtheTrain #795641 12/02/24 08:55 AM
Until I saw this thread I was not aware of the problem.
I have just finished searching the forum on the developer's site ( https://chevereto.com/community/ ) and I found a reference that the extensions were changed to jpeg after the upgrade to version 4 to avoid problems relating to the jpeg extension and to avoid having two naming conventions for what are the same types of files.
Images uploaded before the change are not effected.
To me this is an error because the jpg file extension is the most common, furthermore the permited extensions include both types. I will report this to the developer as a problem that should be a user choice and, in the mean time, investigate the possibility to override this behaviour.
If it is causing a problem in individual cases I should be able to change the extention back to jpg manually.
TM Image Library was set up independently for the use of Talk Morgan forum members
BobtheTrain #795671 12/02/24 05:10 PM
Problem sorted thanks to Alistair's kind advice. Thanks to all who gave me ideas.
Best Regards
Lang may yer lum reek
BobtheTrain #795673 12/02/24 05:22 PM
Black Rat
Black Rat
What a handsome chap toff
Keith
2013 narrow bodied + 4 Ruby.
BobtheTrain #795674 12/02/24 05:49 PM
Smile, it confuses them
Thank you, it's kind of you to say, oh - you mean him...rats.
It's good night from me
