Morgan Aero 8
4 members (MartO, WR142LLJPN, Guern, Simon), 287 guests, and 122 robots.
+8Rich 77
Topics49,868
Posts837,638
Moggo
#795736 13/02/24 06:02 PM
Roady Offline OP
Asking for a friend - does anyone know of a fix for an over-reading speedo (70 on a sat nav reads 70 but speedo reads 90) on a Series 3 Aero? It could be a re-calibration issue but the local dealer can't seem to fix it.
Thanks in anticipation
Series 1 Roadster - the original Plus 6!
Roady #795750 13/02/24 09:58 PM
I have seen a VDO instrument manual, which I recall does give details on adjusting the readout. I'm sure that adjustment was made using the trip meter reset button whilst on the move. Hopefully someone with more information will be along soon.
David
Aero S4
Roady #795816 14/02/24 07:56 PM
There's a USA manufacturer tech support email address here
https://www.vdo-instruments.com/contact-us/
These repair VDO speedos in the UK, (and have done classic Mog repairs) so may give you some phone support
http://www.jdo1.com/contact_details.html
Roady #795844 15/02/24 10:26 AM
Try the below, taken from the article linked in this thread: https://www.talkmorgan.com/ubbthreads.php/topics/79129/Re:_Over_enthusiastic_speedo#Post79129
Calibration of the VDO Speedometer with LCD Display is a relatively simple procedure, and can be accomplished in any of three ways:
• Automatic calibration when driving on a road with the exact distance of l mile clearly defined; or on a dynamometer
• By the input of the known pulse-per-mile (kilometer) for the vehicle and sensor being used with the speedometer...
• Using a reference point for adjustment or fine tuning.
You gain access to the calibration functions by pressing the button on the front of the speedometer and holding it in while you turn on the ignition. As you continue to hold in the button, the display will change ...scrolling through the three calibration methods and stopping on each one for about two seconds.
DIAGRAM F (see above)
The display lists the auto-calibrate mode as AUTOCL; the pulse-per-mile mode as PULSE; and the reference/fine-tune mode as ADJUST. When you see the method you wish to use, let go of the button and that function will be enabled. See Diagram F.
Autocalibration (AUTOCL)
The auto-calibration function can be used successfully only on: A road with the distance of one mile accurately designated or a dynamometer.
To use the auto calibrate mode:
1. Press the button on the front of the speedometer, hold it in, and start the engine. Release the button when the display reads, "AUTOCL"
2. After three seconds, the word "BUTTON" will show on the display. When you are ready to begin your calibration run, press the button again. The display will now begin flashing the word "START."
3. Drive the reference distance of one mile (or 1 kilometer). NOTE: As you drive this distance, the speedometer needle will not register or move. This is a normal occurrence during the auto calibration process.
4. When you have gone exactly one mile, press the button again. If the electronic impulse rate detected by the speedometer's microprocessor is within the calibration range limits of 500 to 399,999, the rate will be shown on the LCD display. For example, your reading might be "P16000 ^ Calibration Range 16000). Such a display indicates that the impulse rate detected during the reference mile you drove exactly matches the microprocessor's programmed rate for 1 mile. That means the speedometer is now perfectly calibrated to provide the most accurate display possible of both speed and distance. The speedometer finishes its Auto calibration by moving the pointer through a full sweep, then back down to zero.
However, if the speedometer detects any kind of error during your run, the LCD will display the following, "P00". This means no useable impulse was detected. In this case, simply turn off the ignition, and start the process again.
REMEMBER: During the autocalibration run, the pointer on the speedometer will not operate.
2. Manual Calibration with a known value (PULSE)
If you know the exact calibration value for the vehicle and type of sensor you are using (pulse-per-mile or pulse per kilometer), you may use that value to manually calibrate the speedometer.
To calibrate your VDO Speedometer manually:
1. Press and hold in the button on the front of the speedometer as you turn on the ignition. Hold in the button until the word "PULSE" is displayed on the LCD readout. See DIAGRAM H below.
2. As soon as you see the word "PULSE," release the button. After a few seconds, the display will start flashing a series of numbers (factory default setting) that you can change to represent the correct calibration impulse value. For example, a number like 50000 will show on the display, with each digit flashing in turn, except for the last digit on the right, which is fixed: first, the second 0 from the right; then the third 0 from the right; then, the next 0; and finally, the 5th.
3. As each number flashes, press the button to change it until the correct digit appears (that is, the number you wish to input).
For example, let's say the number that represents the correct calibration value for your vehicle and sensor is"43850." When you begin the manual calibration process, the LCD displays a default value. Each digit, except the one farthest to the right, will flash, in turn, from right to left. Wait until the second digit from the right starts to flash again. When it does, press the button to start cycling through the numbers available for this digit. When the number "5" appears, release the button.
At this point, the number "5" is set, and the digit to its immediate left begins to flash. Press the button again, and hold it till the number "8" appears. Release the button. Now, the second digit from the left begins to flash. Again, hold in the button until the number "3" appears. When it does, all but the left-most digit are set. Repeat the process to set the "4" and the value in our example is set. The value"43850"should be displayed on the LCD readout.
4. When you are satisfied you have properly entered the correct calibration value - when that value is displayed on the LCD readout - take your finger off the button and wait. After a few seconds, the value you have entered will be downloaded into the speedometer's microprocessor, and the speedometer, will revert back to normal operating mode. At this point, the manual calibration process is complete.
In the future, you can use this method to update the calibration value stored in the computer should it ever become necessary. This function also allows you to manually adjust the calibration value after you perform the automatic calibration process.
3. Manual Calibration (Fine Tuning) (ADJUST)
You can fine-tune the calibration of the speedometer's analog display (the pointer showing miles-per-hour or kilometers-per-hour) by using speed test equipment and the "ADJUST" function on the LCD readout. The pointer can be repositioned anywhere within the calibration range of the speedometer. See DIAGRAM I below.
To manually calibrate the pointer on the analog display with the car on a dyno at the specified speed):
1. Press and hold in the button on the speedometer as you turn on the ignition and start the engine. Hold in the button until the word "ADJUST" shows up. When it does, release the button.
2. Press the button once, and the word "UP" will be displayed on the LCD readout. Press it twice, in rapid succession, and the word "DOWN" will be displayed.
3. When either "UP" or "DOWN" is showing, press the button again, and hold it in. If you hold the button in for just a short time, the pointer will move slowly either upwards or downwards, depending on which mode you selected. This allows for a very accurate adjustment of the pointer. Holding the button in for a longer period of time makes the pointer move faster.
4. When you have repositioned the pointer where you want it, release the button and wait. If no further adjustments are made within one minute, the speedometer will revert back to the normal operating mode.
NOTE: If you move the pointer past the upper limit of the calibration range, the LCD display will flash and you will only be able to adjust the pointer downward. If you move the pointer past the lower limit of the calibration range, the LCD display will also flash, and you will only be able to adjust the pointer upward.
Aero 8 GTN #11
1 member likes this: verysideways
Roady #795863 15/02/24 01:41 PM
^^ that's what i did on mine and it worked - went from over reading by approx 12-15% to being bang on.
I just adjusted the number that was already there by about 12% or so (can't remember the exact figure).
Current - 2013 Plus 8
Previous - 2002 Aero 8 S1, chassis number 96 - Ragusa Green Metallic
Roady #795872 15/02/24 03:09 PM
I concur with above article from Nick and Pete as had to do this after last winter hibernation on my S1 which worked just fine by trial and error and several trips along the local roads with Google Maps on my phone to calibrate and been fine ever since...well have yet to take mine out of this last winter hibernation.
AnDrew G
2003 Aero S1 - past
2009 Aeromax - past
2012 +4 Supersport - past
2008 Aero S4 -past
