11 members (boxboxbox, PaulV, Graham, G4FUJ, riri, WR142LLJPN, SEG, jbk, DaveW, Rastus, Black Adder, meabh), 203 guests, and 35 robots.
+8Rich 96
Luddite 52
Topics49,904
Posts838,076
Page 92 of 164 1 2 90 91 92 93 94 163 164
Originally Posted by Rog
Originally Posted by John V6
Nice. I got an ali version from SiFab
Not so sure that I’m happy with this new stainless T today. Should have got a Sifab ali one… ooo
Out of curiosity today I measured the voltage between the T and the ali rad cooling fins. It was showing around 1v, which is about 3 times more than the other stainless pipework in the cooling system is generating (there are many grades of stainless with a range of different noble potentials). Now I’m suspecting that introducing this grade of stainless is not an ideal mix for the longevity of my super expensive ali rad from a galvanic perspective. I could well be wrong... but have ordered up an aluminum T anyway.
Now that Si-fab is no more, where do you source from? Can’t see any on Fleabay or carbuilder.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Rog Offline
Here you go…. Fleabay
Roger
I've got to get around to changing that T this winter. Rog does the link show the size required?
If I can't buy a welded one I shall make one, but my tig welding is not too good so I might take the fun way out and make from solid.
Rog Offline
I’ve just ordered this one John. As far as I can see the link shows it. Fingers crossed it should be ok! My internal hose diameters are around 16mm.
Roger
Rog, thanks for the info.
I collected mine from the garage where it had its latest mot......guess how many miles it has done in the last 12 months...
Richard S
1993 4/4
1966 VeloSolex
Regards
Geof
70th Anniversary 4/4 (Duratec 1.8), model 1995
Much appreciated, Rog.
However, will wait and see how it fits before getting one. I saw them on fleabay when looking but was a little wary of the diameter of the barb versus the more tapered, multi barbed designs.
The Viper ones suggested by Geoff are multi barbed though a tad more expensive., when adding on postage etc.
Be good to have a report back when done. Thanks.
Doug
1958 Triton 650
I would go with the Viper multi barbed one. Plain ones with just the one lip can be difficult to get a water tight seal on especially with old hoses.
Rog Offline
No problem Doug.
Don't think it will be an issue. It’s the same shape/profile as the other spouts the hose connects to on the car - thermostat, header tank, head outlet manifold etc.
Roger
