0 members (),
323
44
Posts837,276
Posts: 614 Likes: 22
Posts: 614 Likes: 22 |
I have never had this trouble before. I load a pic into an album, select a pic, go to links and it has a link to every pic in that album and I can only select all of them??? What's changed. What am I doing wrong? Cheers John PS forgot to say I am trying to add a pic to a post, never had trouble before.
Posts: 12,255 Likes: 317
Posts: 12,255 Likes: 317 |
Everything seems fine to me. Maybe try logging out and flushing your browser?
I did reboot my PC. My workaround was to copy all the links into the post and then delete the ones I did not want.
Edit I have now cleared the cach and it's still the same. I should say I'm running PC, Win11 with Firefox.
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
Could it be your Firefox browser ? I struggle with Chrome in TMimage (refuses to log me in) and have to swop to MS Edge
Could it be your Firefox browser ? I struggle with Chrome in TMimage (refuses to log me in) and have to swop to MS Edge Yes I could but it has always worked since TMimg was formed.
Posts: 11,520 Likes: 312
Posts: 11,520 Likes: 312 |
Working fine here, Win10-Chrome
Panic over, I'm sure that earlier on I did not get the "action" button on the top right hand side of the screen and so I had to use the "embeded links" button towards the left hand side of the screen, and that gives the links for the whole album and not just for the selected pic. So silly me. Too tired after a long day working on the GDI. Thanks for all the suggestions, Cheers John.
Posts: 2,049 Likes: 12
Sir S1'a'lot Talk Morgan Expert
Posts: 2,049 Likes: 12 |
Yes I gave up the other day. Format is all up the swanny
2002 Aero 8 S1 2023 Plus 4 (woman’s)
My Skandi flat pack explanation.
Computer stuff moves forwards quite quickly. This means some bits fall out of sync. We have two free of charge services that are not selling our information or charging us for our daily fix.
A file is encoded and given a suffix (.jpg) to identify it. This allows an application to know if it can use it or not. These suffixes have been around since mice. They started with 3 letters and were then extended to 4. Image files had a selection of formats including .jpg and .png for example.
Older applications may not understand some newer extensions, so a newer format such as .jpeg might not be understandable to older software.
TM does not currently understand .jpeg as TM is a slightly older package. IMG does understand .jpg and .jpeg. Anything already posted to the site continues to work. However as we try and add a new image through IMG it is failing. When you currently feed IMG an older format like .jpg it tries to be helpful and converts/upgrades it to a newer .jpeg during ingestion. This results in it not being understood by TM.
I got around this by using a file saved in .png format. I used a simple image file application (MS-Paint) to open the file and then saved it as XXXXX.png I then ingested this .png file into TM-IMG and the links worked. PNG has not been updated so is consistent between them.
You can edit a file name, this does not work. Editing the name from xxxx.jpeg to xxxx.jpg results in the software being unable to decode the content.
Peter is aware but I fear the issue will in be effectively solved in an upgrade to allow TM to understand a more modern .jpeg format.
