Topics49,909
Posts838,130
Posts: 177 Likes: 12
Posts: 177 Likes: 12 |
Hi,
Easy question for someone who knows.
Does the Fan Speed Knob simply pull off? or is there a grub screw or something I should know about? I have applied some force but thought I'd ask before really pulling.
This is on 2015 Plus 4 GDI.
Thanks in advance.
Mark 2015 +4 Ferrari Le Mans Blue
Posts: 614 Likes: 22
Posts: 614 Likes: 22 |
There is a grub screw that holds the knob on. If you take the dash under tray off you might be able to get to it. The fan speed knob has the same method of fixing as the temp knob shown here. ![[Linked Image]](https://tm-img.com/images/2024/02/26/DSC03104rs.jpg)
Thanks John, that's saved me some time.
Posts: 27,846 Likes: 764
Posts: 27,846 Likes: 764 |
Definitely a grub screw. Why do you want it off?
I have an idea to replace the 2 speed switch with a 3, but I'd like to keep the original Knob on the new switch so want to take it off to measure up before buying a new one.
If this is possible there would be an additional (spare) position, O would become the 1st On position and be used for a new extractor fan/s, 1 & 2 would be as now.
I've proven the extractor works with a cheap £5 fan, lit a Smoke Match in the passenger footwell and it pulled all the smoke out easily. Just pushing around ideas on how to elegantly implement.
Posts: 2,095 Likes: 75
Posts: 2,095 Likes: 75 |
You might get away by keeping the original switch as it has multi terminals but will probably need to drive your new fan via a relay.
Posts: 1,707 Likes: 36
Posts: 1,707 Likes: 36 |
I have an idea to replace the 2 speed switch with a 3, but I'd like to keep the original Knob on the new switch so want to take it off to measure up before buying a new one. I have this little sketch left over from when I was butchering my dash. The switch shaft diameter is 6.3mm ![[Linked Image]](https://tm-img.com/images/2024/02/26/knob-size.jpg) This switch might work? Worth mentioning that these wafer switches only have a switch rating of around 1A and on the Duratec (don’t know about the GDI) it’s switching the negative side of the relay coil.
Roger 2011 Plus 4
I have an idea to replace the 2 speed switch with a 3, but I'd like to keep the original Knob on the new switch so want to take it off to measure up before buying a new one. I have this little sketch left over from when I was butchering my dash. The switch shaft diameter is 6.3mm ![[Linked Image]](https://tm-img.com/images/2024/02/26/knob-size.jpg) This switch might work? Worth mentioning that these wafer switches only have a switch rating of around 1A and on the Duratec (don’t know about the GDI) it’s switching the negative side of the relay coil. That's really useful info, Thanks
Posts: 1,062 Likes: 156
Posts: 1,062 Likes: 156 |
My plan is to keep the original switch and knob, but just mechanically limit it to two positions, ON & OFF. I'll then use it to ground the coil in the forward relay on this inexpensive 12V 60A PWM motor speed controller. ![[Linked Image]](https://i.ibb.co/cwjHDg6/PWM-CONTROLLER.jpg) https://www.ebay.co.uk/itm/166609762129?itmmeta=01HQMQ959DHV1B9PRKFCKH68QD&hash=item26cab73751:g:dqoAAOSwr2Zl1ksg&itmprp=enc%3AAQAIAAAA0NKPvzZVtPzZLsrOCjbNAIhC9juse%2FBuvF6yroWAKwSFLIVitNdTy9rC9CI59QucmRzhdnLyLj0ql4CuImguEqYIBbLaxv3jg8EFVRriegVlkgGCLRjDZMQgj8y9jjmMJllRxlq9CgAtQk3TWy6CO6zsFkVN%2FtV0Vht58GGveAT76zpNh8UbbXlOwZPuRrjhTqjWZG0IKyoDFeKfn42%2BYdlngQjgqR8Up9pszALVzXCKTu%2Fzo5Mc%2Bbu3cNHr%2BWLScLnf8u8P8WUzeYiaU7%2FaX%2FM%3D%7Ctkp%3ABlBMUJLVpJe9Yw All the higher amp rated PWM controllers seem to have a forward and a reverse relay on the board, but obviously I only need to drive the fan motor in one direction. ![[Linked Image]](https://i.ibb.co/jMDrTc6/PWM-CONTROLLER.jpg) The controller with its surface mounted relays allows me to bypass the problematic PCB, and with the potentiometer mounted in a convenient position under the dash I will enjoy infinitely variable speed control over the heater fan, from super slow to full blast.
My plan is to keep the original switch and knob, but just mechanically limit it to two positions, ON & OFF. I'll then use it to ground the coil in the forward relay on this inexpensive 12V 60A PWM motor speed controller. ![[Linked Image]](https://i.ibb.co/cwjHDg6/PWM-CONTROLLER.jpg) https://www.ebay.co.uk/itm/166609762129?itmmeta=01HQMQ959DHV1B9PRKFCKH68QD&hash=item26cab73751:g:dqoAAOSwr2Zl1ksg&itmprp=enc%3AAQAIAAAA0NKPvzZVtPzZLsrOCjbNAIhC9juse%2FBuvF6yroWAKwSFLIVitNdTy9rC9CI59QucmRzhdnLyLj0ql4CuImguEqYIBbLaxv3jg8EFVRriegVlkgGCLRjDZMQgj8y9jjmMJllRxlq9CgAtQk3TWy6CO6zsFkVN%2FtV0Vht58GGveAT76zpNh8UbbXlOwZPuRrjhTqjWZG0IKyoDFeKfn42%2BYdlngQjgqR8Up9pszALVzXCKTu%2Fzo5Mc%2Bbu3cNHr%2BWLScLnf8u8P8WUzeYiaU7%2FaX%2FM%3D%7Ctkp%3ABlBMUJLVpJe9Yw All the higher amp rated PWM controllers seem to have a forward and a reverse relay on the board, but obviously I only need to drive the fan motor in one direction. ![[Linked Image]](https://i.ibb.co/jMDrTc6/PWM-CONTROLLER.jpg) The controller with its surface mounted relays allows me to bypass the problematic PCB, and with the potentiometer mounted in a convenient position under the dash I will enjoy infinitely variable speed control over the heater fan, from super slow to full blast. A novel solution. Just make sure that those heat sinks are well. away ( and stay away) from any wiring insulation when it’s fitted into the confines behind the dash. 🔥
