6 members (+8Rich, Adam12, RichardV6, TBM, Lordofthewings, DJC), 290 guests, and 39 robots.
Adam12 66
+8Rich 64
John V6 61
9,215 Registered Users
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,365
Posts813,372
Members9,215
Rbt Aero8, Salmon, stevends
Page 1 of 4 1 2 3 4
#796514 26/02/24 03:23 PM
Mark+4 Offline OP
Hi,
Easy question for someone who knows.
Does the Fan Speed Knob simply pull off? or is there a grub screw or something I should know about? I have applied some force but thought I'd ask before really pulling.
This is on 2015 Plus 4 GDI.
Thanks in advance.
Mark
2015 +4 Ferrari Le Mans Blue
Mark+4 #796517 26/02/24 03:59 PM
There is a grub screw that holds the knob on. If you take the dash under tray off you might be able to get to it. The fan speed knob has the same method of fixing as the temp knob shown here.
Mark+4 #796523 26/02/24 04:10 PM
Mark+4 Offline OP
Thanks John, that's saved me some time.
Mark
Mark+4 #796528 26/02/24 05:04 PM
Definitely a grub screw. Why do you want it off?
2025 MG ZS EV aka Trigger
Mark+4 #796529 26/02/24 05:30 PM
Mark+4 Offline OP
I have an idea to replace the 2 speed switch with a 3, but I'd like to keep the original Knob on the new switch so want to take it off to measure up before buying a new one.
If this is possible there would be an additional (spare) position, O would become the 1st On position and be used for a new extractor fan/s, 1 & 2 would be as now.
I've proven the extractor works with a cheap £5 fan, lit a Smoke Match in the passenger footwell and it pulled all the smoke out easily. Just pushing around ideas on how to elegantly implement.
Mark
Mark+4 #796532 26/02/24 06:12 PM
You might get away by keeping the original switch as it has multi terminals but will probably need to drive your new fan via a relay.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Mark+4 #796535 26/02/24 06:50 PM
Rog Offline
I have this little sketch left over from when I was butchering my dash. The switch shaft diameter is 6.3mm
This switch might work?
Worth mentioning that these wafer switches only have a switch rating of around 1A and on the Duratec (don’t know about the GDI) it’s switching the negative side of the relay coil.
Roger
Rog #796551 26/02/24 09:14 PM
Mark+4 Offline OP
That's really useful info, Thanks
Mark
Mark+4 #796567 27/02/24 08:05 AM
My plan is to keep the original switch and knob, but just mechanically limit it to two positions, ON & OFF.
I'll then use it to ground the coil in the forward relay on this inexpensive 12V 60A PWM motor speed controller.
https://www.ebay.co.uk/itm/166609762129?itmmeta=01HQMQ959DHV1B9PRKFCKH68QD&hash=item26cab73751:g:dqoAAOSwr2Zl1ksg&itmprp=enc%3AAQAIAAAA0NKPvzZVtPzZLsrOCjbNAIhC9juse%2FBuvF6yroWAKwSFLIVitNdTy9rC9CI59QucmRzhdnLyLj0ql4CuImguEqYIBbLaxv3jg8EFVRriegVlkgGCLRjDZMQgj8y9jjmMJllRxlq9CgAtQk3TWy6CO6zsFkVN%2FtV0Vht58GGveAT76zpNh8UbbXlOwZPuRrjhTqjWZG0IKyoDFeKfn42%2BYdlngQjgqR8Up9pszALVzXCKTu%2Fzo5Mc%2Bbu3cNHr%2BWLScLnf8u8P8WUzeYiaU7%2FaX%2FM%3D%7Ctkp%3ABlBMUJLVpJe9Yw
All the higher amp rated PWM controllers seem to have a forward and a reverse relay on the board, but obviously I only need to drive the fan motor in one direction.
The controller with its surface mounted relays allows me to bypass the problematic PCB, and with the potentiometer mounted in a convenient position under the dash I will enjoy infinitely variable speed control over the heater fan, from super slow to full blast.
Montegue #796570 27/02/24 08:36 AM
A novel solution. Just make sure that those heat sinks are well. away ( and stay away) from any wiring insulation when it’s fitted into the confines behind the dash. 🔥
Doug
1958 Triton 650
Page 1 of 4 1 2 3 4
