10 members (bmgermany, MJF, JoeSpeetjens, RichardV6, John Winn, SailingTom2, Strathaven, uvk33n, Joske Vermeule, Stevo666), 266 guests, and 30 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,146
Page 4 of 4 1 2 3 4
Rog #796784 01/03/24 07:47 AM
Originally Posted by Rog
Dave, is that a bi directional pot? If you swapped it for a regular single direction long shaft pot, with a switch incorporated, it might all fit neatly in place of the Lorin switch. Then you would have full control using the standard knob.
Wow, what a super neat solution that would be woohoo
Great idea Rog, I'll investigate thumbs
Mark+4 #796788 01/03/24 09:32 AM
TBM Offline
Much more analogue solution, but I fitted one of these https://www.carbuilder.com/uk/fan-speed-conversion-switch-three-position
I already had a three speed fan on the aftermarket heater, but the fan was so powerful that even on the lowest setting it was cooling the heater matrix. I fitted it into the lowest fan setting, and now get a consistent warmth from the heater. It does mean I have a 5 speed fan setting!
Mark+4 #796880 02/03/24 04:58 PM
Mark+4 Offline OP
Just took the switch of the car and after some continuity testing can confirm.
Fitted to my GDI is a 3 position 4 pole switch.
I tried connecting Poles A & B together and confirmed that positions 1-6 then had a single pole.
I didn't understand the discussion around combining poles to provide more Amps, and I don't know at this stage how many Amps I need, I will need better (Waterproof) Fans and probably will go for 2, I just had 1 for testing, so will continue along the Relay route to be safe.
So next thing to do is get a wire through to the fuse box and re-solder the leads to the right positions, then the Switch and Dash can go back together.
Mark
2015 +4 Ferrari Le Mans Blue
Mark+4 #796902 03/03/24 08:24 AM
Online NoMood
Mark see below, specifically the 4 pole 3 way variant you have proven you have.
If you were to connect poles A, B, C, D together. Then connect positions 1, 4, 7, 10, then 2, 5, 8, 11 and so on for position 3, you would end up with a single pole 3 way switch. Because the current was split four ways though the switch would handle 4 amps.
You require 4 positions though so the 2 pole 6 way switch variant with the mechanical stop set at position 3 would be a good choice. You could still double up the two poles and four positions as above to achieve 2 amp current handling.
Hope this makes sense.
Rog #796905 03/03/24 09:25 AM
Originally Posted by Mark+4
I have an idea to replace the 2 speed switch with a 3, but I'd like to keep the original Knob on the new switch so want to take it off to measure up before buying a new one.
I have this little sketch left over from when I was butchering my dash. The switch shaft diameter is 6.3mm
This switch might work?
Worth mentioning that these wafer switches only have a switch rating of around 1A and on the Duratec (don’t know about the GDI) it’s switching the negative side of the relay coil.
This was demonstrated to me by the mechanic at Borghi's after I had burnt out the circuit board and was part of the incentive to change my dash. When the fan is running at high speed and you turn the engine off you see the various dash warning lights fade slowly because the spinning fan motor becomes a generator and feeds power back into the system.
It almost makes one wonder if the heater fan system goes back to when cars had a positive earth system thinking
Part of Borghi's dash fix was to reverse the wiring to the fan to the more conventional system so that power goes to the fan from the switch/relay rather than the fan constantly having power and being earthed via the switch/relay. I don't know the technical details of how this was done.
Mark+4 #796909 03/03/24 11:32 AM
Mark+4 Offline OP
Hi,
Any ideas why positions 2 & 8 have been connected?
2 is Fan position 1 (low), nothing connected to 8.
I want to move 2 to 3 so should I also move this connection?
Mark
Mark+4 #796915 03/03/24 12:27 PM
Online NoMood
No idea Mark. All the connections I've seen just use the A pole ground (black), position 2 fan slow (blue) and position 3 fan fast (yellow or slate).
Mark+4 #796916 03/03/24 12:35 PM
Rog Offline
Ditto - Is that a secondhand switch I see, that might have been used before?
PS – Mark, be super cautious modifying your car… thumbs
Roger
Online NoMood
The fan motor itself cannot have a permanent live connection Peter since there are two speeds each requiring a switched positive feed. It's only the relays that have permanent live feeds to their coils allowing ground/return triggers, one each for fast and slow fan selection.
Ground triggered relays tend to be the norm now.
Rog Offline
I wonder if that was the reason they poked these two diodes (on later cars) into the high/low motor feeds, in an ‘attempt’ to suppress some of the motor’s back EMF and protect the PCB?
Roger
Page 4 of 4 1 2 3 4
