5 members (lez, TBM, Sir Percival, Julian BB, John V6), 214 guests, and 119 robots.
+8Rich 101
John V6 66
Longest owner?
Suspension upgrades
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,920
Posts838,275
Smed., Spanner Juggler
#797262 09/03/24 09:03 PM
PaulyG Offline OP
I took apart my Restall seat bottom. After 50 years the padding is pretty much gone away, and I seem to have less of my own personal padding as well. The picture below is the wooden base for the seat. I'm going to replace the webbing because the old stuff is kind of failed. I'm also thinking that I can make the cut out in the seat bottom a little bigger, which should give a little more springiness to the new webbing. I also see that the hole is cut straight through which puts a fairly sharp edge around the side with the cushion. Well my thought is to follow the pencil marks roughly and open up the seat and round out the edge so that part gets a little more comfortable. I'm going to add if possible a half an inch of very heavy foam padding with the softer seat padding on top of it. I'm looking for a combination of a more comfortable seat, without gaining very much height. As it is with the hood up, my head is about a half an inch from the fabric.
Has anybody done anything like this with the seat base? I don't think it will affect where it sits in the frame because the frame is farther outside the cut marks. And it is plywood so it should retain some of its strength, probably more than is needed.
73 4/4 "Henry A"
53 +4 Flat Rad "Pug"
84 Citoen 2CV Spec "BeBe"
60 MGA
https://morgan34.org/
PaulyG #797285 10/03/24 11:32 AM
I've never altered the wood but I did replace my foam with memory foam which made a huge difference to the comfort.
nick w #797290 10/03/24 01:50 PM
PaulyG Offline OP
Did you start with a block of memory foam and shape it? How did you cut it? What size did you start with?
73 4/4 "Henry A"
60 MGA
PaulyG #797291 10/03/24 01:57 PM
Back in my biking days, I found that an electric carving knife was ideal to cut and shape upholstery foam.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
1 member likes this: PaulyG
PaulyG #797308 10/03/24 05:07 PM
I bought a mem foam pillow and used that.
Exactly as Doug says, the electric carving knife gives a very accurate cut.
