7 members (Robbie, Burgundymog, Sir Percival, gaston, SteveD, jbk, TalkMorgan), 346 guests, and 54 robots.
+8Rich 92
Topics49,837
Posts837,286
lez #798113 29/03/24 05:54 PM
One of the best upgrades I did was a DIY fitting of heated seats with a £40 eBay kit… bit daunting taking seats out but once you do the passenger first the second is easy..
The only challenge I had was what to wire it into for the power…
lez #798138 30/03/24 09:28 AM
Has anyone any experience of heated jackets / gillets. They seem a great idea but I can't imagine the battery packs would last for anything other than a short journey.
lez #798140 30/03/24 09:42 AM
SFG Offline
Mine lasts long enough for a full round of golf
SFG
2012 4/4 Sport
pheasant #798142 30/03/24 10:00 AM
TBM Offline
If you get a Keis one, you can plug it in to the car battery - I used one on by bike for years when I used to commute on it all year round.
lez #798147 30/03/24 03:06 PM
My battery lasts 3 or 4 hours on the medium heat setting, but as TBM says, you can plug it into your battery or cigarette lighter.
2009 4/4 Sport in Red
2022 Harley Davidson FXLRS Low Rider S
1977 Triumph Stag
pheasant #798172 31/03/24 07:02 AM
This could be a helpful thread
Clemens
PlusFour Red Baron MY 2022
lez #798189 31/03/24 11:58 AM
I have a heated undershirt which I use when I have to go out for long periods in exposed forestry, it has 3 heat settings accessed by a front button. It works a treat, the heating pads are on its back, so I would say to anyone thinking of a heated garment consider where the heating pads are located. With reference to battery life, the standard power bank ( battery ) is a 3.7V 5000mAH this will last for at least 4 hrs on max heat, but for all day comfort I also have a 10,000 mAH battery, the only downside is its a little heavier. Both units charge from a USB port or USB mains adaptor and fairly quickly. Various rated power banks are available online, so depending on your use just find the right size battery.
The undershirt washes like a normal garment, the battery is of course first removed ( it normally sits in its own little shirt side pocket ) and there is a plug to be pushed over the wiring connector, which is then secured in the side pocket. It is then placed in a little zipped nylon bag and into the washing machine.
Dave
Plus Six "Squeak"
Roadster departed.
