8 members (ChrisConvertible, JohnHarris, Stephen888, JMcL, SEG, Alan Patterson, TBM, stumog),
207
54
Topics49,871
Posts837,676
Posts: 580 Likes: 2
Posts: 580 Likes: 2 |
The rear drum brake on my 2012 three wheeler is binding slightly at two points possibly due to fractional ovality. This makes a lot of noise. I have checked by jacking the rear up that everything else is tight and this seems the only source of the noise. I cannot see any manual adjustment on the back of the drum or a hole to adjust internally. Am I correct in assuming that there is a cam and ratchet device inside the drum to take up wear and the only way it can be slackened off, is to take the whole thing apart and release the ratchet?
Posts: 582 |
Yes the adjustment is automatic (some times). You must take the drum off to manually adjust the shoes. Check the drum for true while its off and lubricate all the sliding parts in the mechanism also
Posts: 580 Likes: 2
Yes the adjustment is automatic (some times). You must take the drum off to manually adjust the shoes. Check the drum for true while its off and lubricate all the sliding parts in the mechanism also I think it may have been rusty patches on the drum from being in storage for 6 months (may have had the hand brake on). After putting about 600km onto it over the last few weeks, seems to be pretty much OK now. It is going into storage again next week in France for when I go back to the UK until spring. I have printed a large notice in red, saying "PLEASE LEAVE ME IN GEAR WITH HANDBRAKE OFF". Must remember to pump the front tyres up to 40+ PSI to stop flats. Wilson
