5 members (Clipper, bmgermany, jbk, RedThree, mph), 199 guests, and 86 robots.
Topics49,847
Posts837,389
#798478 05/04/24 10:14 PM
riri Offline OP
Hello,
I found in the Morgan those things: on the bulkhead a brass thing with two elektric ports and in the front a relais wiht a fuse. do you know for what these things are good?
dear riri
ps: i cant add pictures in this place
Greatings from germany, +8 1997 3,9 l blue
riri #798479 05/04/24 11:49 PM
riri Offline OP
how can I add pictures?
riri #798482 06/04/24 03:23 AM
It sounds like you have power feed for an earlier generation inspection lamp.
As for photos, you have to host them on another photo hosting site and provide a link to them or you could post your photos in the actual photo section, then copy to the thread here.
There is a photo hosting site www.tm-ing.com provided by a member on here. It also has a useful guide as to how to link your photos to this and other sites.
riri #798490 06/04/24 06:56 AM
riri ... if you're really stuck posting a pic until you get faniliar with the system, let me know .... I can PM you my email and you can send it there and I'll post it up for you.
riri #798492 06/04/24 07:18 AM
riri following Graham's suggestion do your electrical connectors look like these on top left of my Land Rover panel.
If so they were provided to power optional inspection lamp when used with matching plug.
A typing error has crept in, Graham. It's www.TM-IMG.com 🙂
riri #798555 07/04/24 10:53 AM
riri Offline OP
riri #798556 07/04/24 11:07 AM
TBM Offline
The brass thing is a disconnected kingpin oiler, so nothing to do with the wiring.
riri #798557 07/04/24 11:09 AM
TBM Offline
The other wires look like they're connected to the coil, so maybe part of a removed electronic ignition system?
riri #798559 07/04/24 11:26 AM
To display correctly, select the line which reads BB Code below your picture and copy / paste the resulting sequence:
Costock, UK
Disco 5
