Topics49,847
Posts837,389
Posts: 29 |
The Morgan ist an 1997. 3,9 l +8
Greatings from germany, +8 1997 3,9 l blue
Posts: 28,894 Likes: 351
Posts: 28,894 Likes: 351 |
There is a photo hosting site www.tm-ing.com provided by a member on here. It also has a useful guide as to how to link your photos to this and other sites. A typing error has crept in, Graham. It's www.TM-IMG.com 🙂 Early morning typing - Oooops! Thanks for correcting Heinz
Posts: 29 |
Does anyone know what the elektric plugs on the central lubrication system are for?
Posts: 6,667 Likes: 433
Posts: 6,667 Likes: 433 |
If standard Lucas Wiring colours are used -
White with black tracer is Ignition coil contact breaker to distributor contact breaker, or distributor side of coil to voltage impulse tachometer Pink and White is Ballast terminal to ignition distributor Black and White is Brake fluid level warning light to switch and handbrake switch Plain White is Ignition switch or starter solenoid to ballast resistor Plain Green is Accessories fuesed via ignition switch Plain Black is Earth Not sure about the plain yellow.
So my guess (and it is a guess) would be the Black/White plug should go to a fluid sensor on top of the brake master cylinder and the other plugs are part of a previous, now removed, coil/ignition booster/electroic system.
Posts: 2,221 Likes: 181
Posts: 2,221 Likes: 181 |
Below your Clutch fluid reservoir is the brake servo reservoir the cap on this reservoir should have two electrical terminals. Does your cap have two electrical terminals? If it does are wires connected? If it has two electrical terminals and the wires are not connected then I believe these two electrical connectors are for those terminals.
Looking at the photo of your clutch fluid reservoir the fluid it looks very dark I would check and change the clutch fluid.
Posts: 29 |
Thank you, i will look, an than i write again. bey riri
