0 members (), 240 guests, and 90 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
riri #798560 07/04/24 11:41 AM
riri Offline OP
The Morgan ist an 1997. 3,9 l +8
Greatings from germany, +8 1997 3,9 l blue
Heinz #798564 07/04/24 12:49 PM
Originally Posted by Heinz
Originally Posted by Graham
There is a photo hosting site www.tm-ing.com provided by a member on here. It also has a useful guide as to how to link your photos to this and other sites.
A typing error has crept in, Graham. It's www.TM-IMG.com 🙂
Early morning typing - Oooops!
Thanks for correcting Heinz thumbs
riri #798656 08/04/24 04:26 PM
riri Offline OP
Does anyone know what the elektric plugs on the central lubrication system are for?
riri #798658 08/04/24 04:50 PM
TBM Offline
If standard Lucas Wiring colours are used -
White with black tracer is Ignition coil contact breaker to distributor contact breaker, or distributor side of coil to voltage impulse tachometer
Pink and White is Ballast terminal to ignition distributor
Black and White is Brake fluid level warning light to switch and handbrake switch
Plain White is Ignition switch or starter solenoid to ballast resistor
Plain Green is Accessories fuesed via ignition switch
Plain Black is Earth
Not sure about the plain yellow.
So my guess (and it is a guess) would be the Black/White plug should go to a fluid sensor on top of the brake master cylinder and the other plugs are part of a previous, now removed, coil/ignition booster/electroic system.
riri #798675 08/04/24 11:23 PM
Below your Clutch fluid reservoir is the brake servo reservoir the cap on this reservoir should have two electrical terminals. Does your cap have two electrical terminals? If it does are wires connected? If it has two electrical terminals and the wires are not connected then I believe these two electrical connectors are for those terminals.
Looking at the photo of your clutch fluid reservoir the fluid it looks very dark I would check and change the clutch fluid.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
riri #798811 11/04/24 01:23 PM
riri Offline OP
Thank you, i will look, an than i write again.
bey riri
