5 members (Farmershands, Strathaven, TeddyAds, Pundit, MartinB60), 232 guests, and 89 robots.
+8Rich 79
DaveW 50
Topics49,866
Posts837,588
#799315 23/04/24 10:07 AM
sewin Offline OP
Does anyone know of a supplier where I can obtain suitable glove box hinges for a walnut dash on a 2010 car. Mine has only covered under 8000 miles and the hinges have basically disintegrated so its certainly not from over use!
sewin #799317 23/04/24 10:34 AM
sewin #799318 23/04/24 10:45 AM
If they are piano hinges then ebay has lots of options
sewin #799321 23/04/24 11:53 AM
sewin Offline OP
Thanks, Brownbaker they are not the ones unfortunately and John they are not piano hinges. they are basically butt hinges 25mm long by 19mm wide with 2 screw holes per leaf, so 4 screws per hinge. brass chrome plated. so far the closest is,...... believe it or not -screwfix. yes they're plain brass but that doesn't worry me too much, might have to reposition the holes as the MMC option seems to be closer to the ends of the hinge but they do look like they came out of a lucky bag and might have been stronger had they been made of shiny plastic! I will pick a set up as soon as I can visit the nearest screwfix! After all ,I think here I just might have to adopt the "They're going to fit" option.
1 member likes this: John V6
sewin #799331 23/04/24 01:40 PM
I don't know if these are available through Amazon.UK, but you might check it out. You could polish the stainless to approximate the chrome finish.
https://www.amazon.com/Adiyer-Stainless-1-inch-Folding-Jewelry/dp/B08SJBD3L1?th=1
sewin #799351 23/04/24 07:08 PM
sewin Offline OP
Thanks sailor, that's exactly what I want, cant find any available though.....Drat!
sewin #799367 23/04/24 10:04 PM
This any good?
https://www.amazon.co.uk/ManLee-Stainless-Folding-Miniature-Furniture/dp/B08QZH9Q1H/ref=sr_1_5?crid=1IKN47N3CI9XP&dib=eyJ2IjoiMSJ9.gltmeRhpNAMU54IhYhnIJdZVEZaTOhswEDQUDknkNrSHuz2bQw9LS8CjjKDXhovq3lXoNTiKwo_ibgTtBVfRDzBuTTJL9hURRABS5bk2E3N_cYSW0O3OUMn5h-Iagx9rFQ8uKR0DmmubqpBq_a5b6eOvkXpHQre63XuY02Atl_evwNai9iMKHh4QB0I4IPcGavO3-OGsw2CUPIqnzYYmb5USntw-1tsHksvNOCbLWmi5FpVD3iNiuH7lRG5ZwOdkp_6Aq0HHHLyFYLjmzhu4ueuV1zak0cIwv2E2vQVfy7A.vLDH6rG4yymUUSJTiX1A-wu3Rs6lRjGq9RgHFqUCFkg&dib_tag=se&keywords=1-inch+Folding+Butt+Hinges+Small+Hinges&qid=1713909720&sprefix=1-inch+folding+butt+hinges+small+hinges%2Caps%2C255&sr=8-5
sewin #799370 24/04/24 02:55 AM
Sewin, look at Car Builders Solutions and Europa Spares' websites, loads of stuff on there and both recommend ....
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
sewin #799566 27/04/24 08:23 PM
sewin Offline OP
Well I finally found a good replacement set. Those 1854sailor found were exact but they wouldn't ship from the USA. I finally got a set that were a perfect replacement fit. size and hole alignment and, they are way superior quality than the original fitment. Yes they are not finished in chrome but brass is OK! and quite honestly they actually disappear rather than shining out at you, so I'm kind of liking them now. They were from a seller named (agtrading12) on eBay so if anyone else needs them that's a source.
I have bought a few and most were not a match but these were perfect. Most failed on hole matching and/or material thickness but these were spot on in fit and function just better made and certainly more robust. I had tried several Morgan options including the works but as yet I have had no responses.
sewin #799577 28/04/24 07:00 AM
Good result, but a part number or item number would be more useful to find the part, if you have it please?
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
