4 members (Bishmog, Ricardo, Stevo666, John V6), 302 guests, and 17 robots.
John V6 69
DaveW 65
+8Rich 62
Dufty, Anted4, 4199, GOFFO1965, Joske Vermeule
9,212 Registered Users
First Morgan
195/60 R15 for 2018 Plus4
by Soleng - 24/07/25 05:32 PM
MulFab and Petrol Tanks
by Rovert - 24/07/25 09:51 AM
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Topics48,349
Posts813,091
Members9,212
aeroed, DJC, James Mc, JimWhin
#799233 21/04/24 09:26 PM
Grumpy2 Offline OP
Been reading about this and it seems quite common in some circles. Has anyone here experience of blinking the egr on a 2.0 duratec, did it make any difference?, cause any problems.
Something here on it and source of blanking plate. Only thought are possibility of increased emissions at MOT time thinking
The actuator failed on mine last year after about 47k miles, and resulted in a MIL light. A devil to get at. I got it replaced. ( very little in the way of soot/ carbon deposits.)
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Grumpy2 Offline OP
Yes I’d seen that and it got me wondering. No info on what you do with the existing wiring and pipe though. And like you I wondered what happens come MOT?
EGR blanking is a no brainer, It'll deliver much improved throttle response.
Combine with a swirl flap delete for a nice cheap horsepower gain too.
Just leave the systems thinking everything is still in place, and the ECU will remain happy.
Not Duratec related but my Landy has had the EGR blanked for years and never had a problem passing its MOT ... nothing intrinsic to blanking that would cause a fail in a decent condition engine.
Coming from the LR fraternity I have had some experience with EGR blanking and it has it's plus's and minus's . Really, unless you are looking to get every cent of power from the engine then when applied to a petrol engine it's not hugely advantageous. On a diesel engine with all the muck that is being recycled then that's a different matter. Think the VW fix after the scandal! All the fix basically did was to up the amount of gasses being recirculated through the engine, This in fact caused greater problems!
If you blank the EGR The MIL light will come on and stay on lodging a fault, this will not effect performance but won't pass an MOT as the MIL light is on . One check now at MOT is to ascertain that the EGR system has not been bypassed if the design requires it to be there and functioning! LR owners got over this by installing a blank with a smaller central hole. The idea being that you would find the blank with the smallest hole your vehicle could function with without the MIL coming on. This greatly reduced the returned gasses but not all obviously. Diesel engines get through EGR valves like like its a service item!
Better on a petrol engine and then only really with a direct injection variant would be to clean the gasses as best you can. On a well maintained and serviced engine the rocker box gasses tend to be minimal so I would leave that part alone but on the crank case breather I would install an oil catch can of the 'not open to atmosphere type' and on the out connector, reconnect it to the inlet manifold to maintain crankcase breathing as the engine was designed to do. Honestly, blanking the EGR valve alone will not give you stunning performance!
Exhaust gas recirculation (EGR) is just a strategy used in petrol and diesel engines to reduce emissions, more specifically its used to reduce nitrogen oxide. Because the air entering your engine is 80% nitrogen and 20% oxygen, if you replace some of the air with exhaust gasses you can reduce the levels of oxides of nitrogen, counterintuitively EGR actually reduces combustion chamber temperatures under part throttle situations thus further reducing NOx.
What you'll find is the EGR strategy only actually comes into play once the engine is fully warmed, and even then it also only really operates at idle and during very low engine loads such as under cruise conditions. This is why on older petrol engines like the Duratec, Ford linked it's operateration to engine vacuum.
With internal combustion engines the idle condition is always very inefficient, volumetric efficiency is extremely poor at idle so not all the fuel burns resulting in a significant increase in the hydrocarbon gasses emitted from the tailpipe, reintroducing those fuel rich gasses into the engine to be reburnt before they're emitted to the environment is therefore definitely a good idea. However, EGR systems are not 100% reliable, failures are common with a faulty EGR valve resulting in a rough idle and performance issues including a loss of power, reduced acceleration and decreased fuel efficiency, ironically when it starts to play up it will also cause vehicle emissions to increase.
Because the EGR system is not in operation when the engine is under load and at wide open throttle, removing it will have zero effect on outright performance so don't expect an EGR delete it will give you another 10 horsepower at the dyno, because it absolutely won't, indeed it won’t even give you a 1 horsepower gain! However because the EGR valve is open at idle it will have a negative impact on throttle response, that is the moment you apply the throttle known as 'Tip In', but only for that split second you transition from idle to a driving state, in this respect EGR has an impact on throttle response much like the negative effects of a vacuum leak.
Blanking the path of exhaust gasses being reintroduced to your engine will definitely improve throttle response as you pull away off junctions, if you then combine this with a swirl flap delete the improvement will be even more pronounced, you'll also be removing a potential point of failure that is the ERG system.
Your NOx levels will increase though, in my opinion this is more of a personal choice thing as I doubt you'll have an issue at MoT time, if you do a lot of town driving where extended periods of idle are common and your exhaust tail pipe will come into close proximity to pedestrians you may choose to keep the EGR system out of respect for your fellow man, otherwise I'd blank it off and enjoy the crisper throttle response.
Also keep in mind a blanking plate can't be seen by your ECU, so as long at the valve remains connected and operational the ECU will continue to instruct it so no fault will be throw, remember the old Ford Visteon ECU used on our Duratec plus 4s is only sampling the oxygen content in your exhaust pre and post catalyst and it does so using very old tech narrow band lambda sensors that are only accurate around stoich (14.7:1 AFR), the ECU is not directly measuring NOx so again you can be reassured a fault code is extremely unlikely.
If you're not driving around the city all day long, if you like crisp throttle response off idle and you want to eliminate a system that's known to fail from time to time, an EGR blanking plate is a nice cheap mod. I'd also recommend deleting the swirl flap system at the same time as it's just a massive inlet manifold restriction, better still fit a Fusion Fabrications long runner inlet manifold with internal velocity stacks and along with a big improvement in throttle response you'll enjoy a nice uplift in torque.
https://www.talkmorgan.com/ubbthreads.php/topics/777958/monty-takes-a-deep-breath
Grumpy2 Offline OP
I’ve been looking at the blanking options and there seem to be two types. One simply sandwiches a plate between the EGR and the head leaving everything else in place. The other removes the EGR and replaces it with a plastic mounting leaving the pipes and electricals dangling.
The access looks a bit of a PITA as it’s at the rear up against the bulkhead but otherwise looks a simple enough thing to try. Hmmmmm
