Posts837,276
Posts: 318 Likes: 5
Posts: 318 Likes: 5 |
I've just discovered I've leaked most of my brake fluid from one of the rear brake cylinders so now need to replace them both and the rear shoes. Can anyone advise if these are from another car or do I have to pay the Morgan premium?
Posts: 37,403 Likes: 977
Posts: 37,403 Likes: 977 |
If you have Girling brakes, which I suspect due to the year I can't help you there but others will. If you have Lockheed/ AP brakes I can give you the alternatives that I bought and fitted to my 1999 Plus 8. Maybe worth a look around this siection.
Posts: 1,616 Likes: 142
Posts: 1,616 Likes: 142 |
Common to Scimitar and Austin A60 (and its BMC variants)
Delphi BSS 7067 should do the trick
Arwyn
Posts: 318 Likes: 5
Thanks. I found the Girling wheel cylinder number as GWC1104 . The Delphi number doesn't seem to come up on a Google search for some reason.
Unfortunately I'm booked into a car run tomorrow which will have to be cancelled and also a car show today. And it's ideal top off weather today too!
Posts: 52 Likes: 2
Posts: 52 Likes: 2 |
I hade a leaking rear cylinder last year, a new one was about £25 from eBay, took about three days to come.
Mark
1979 4/4 crossflow engine by Colin Musgrove, twin 40’s
