Topics49,847
Posts837,389
Posts: 51 Likes: 17
Posts: 51 Likes: 17 |
So the.sliding window was rattling and I fitted replacement felt material from Melvyn. It was a leap of faith to remove the sliding window but I found no way could I get the window back in with the new felt in position. I then refitted the original lining material along the bottom thus enabling the window to be refitted but now the window cannot be opened as it is still such a tight fit. I checked with Melvyn that I have the correct stuff and I am fitting it correctly creating a āUā channel with the flat material first. Has anyone got any ideas please?
2002 4/4 Zetec Indigo Blue purchased July 2023 my first Morgan
Posts: 1,616 Likes: 142
Posts: 1,616 Likes: 142 |
Might need to relieve the side screen height a bit, I use 120 grit wet and dry around a rubber sanding block kept well lubricated with warm soapy water.
You could also check the channel is absolutely clear - when I did the same job on my 1971 car, it seemed the factory placed a very thin packing strip under the lining material - bit difficult to see at first but picked out with a scriber!
Arwyn
Posts: 8,667 Likes: 408
Posts: 8,667 Likes: 408 |
The U channel on my later car is rubber not felt which may give greater clearance although cannot find it listed by MMC or elsewhere. Do Woolies offer it I wonder  BTW I read recently that when stripping side screen frames for painting the channeling adhesive needs to be removed with solvent. I wonder this is what Arwyn refers to.
Posts: 123 Likes: 6
Posts: 123 Likes: 6 |
I rebuilt my sidescreens with new channels and importantly windows... It wasn't easy, but the new windows had more flex to get them in then the older sun exposed perspex.
Would new perspex, plexiglass or whatever you choose help?
Posts: 1,500 Likes: 2
Posts: 1,500 Likes: 2 |
I just put a piece (about 1" by 1" by 1/4") of foam rubber insulation between the two plexiglass panels at the top of side curtain. One side had a plastic (?) cover over what I suppose was some sticky glue. I left the plastic in place and it slides when I open the window, while the side, with no plastic, stays in place. If it falls out, I just make another!! Stops the rattle for me!
Mark
1934 SS MX4 1938 Series 1 DHC 1951 Plus 4 2005 Roadster
