9 members (MartinB60, Guten, Strathaven, nestor59310, Graham, G4FUJ, +8Rich, Fuel.inj, James B W, 2949olivier), 294 guests, and 39 robots.
+8Rich 92
Posts837,279
#800369 14/05/24 10:05 AM
The TM Image Library tm-img.com is not part of the Talk Morgan forum but was set up by members for the use of Talk Morgan forum members following a debacle with a then popular image hosting site.
tm-img.com uses the Chevereto image hosting software. Some months ago the developer decided that all images with the .JPG extension should be converted to the .JPEG extension. The two types are identical and it is only the naming convention for the extension that differs.
This caused problems for some sites, including those running on UBB.threads as used by Talk Morgan. It did not cause a problem with embedded images but did cause a problem for images used for an avatar on UBB.threads (Talk Morgan) which must be must be .JPG, .PNG, or .GIF
Following my request the developer has now modified the software so that .JPG files uploaded to tm-img.com now retain the original extension.
If you have a file that uses the .JPEG extension (some cameras and Apple), and you want to use it as an avatar, simply change the extension to .JPG before uploading it.
This is not necessary if the image is the be embedded in a post.
If you use an image stored on any image hosting service as an avatar on Talk Morgan you must use a direct URLfor the image, not embed codes.
For example:
Code
https://www.tm-img.com/images/2019/08/18/000000000000072880_E1.th.jpg
Contact me for any further clarification.
TM Image Library was set up independently for the use of Talk Morgan forum members
3 members like this: OZ 4/4, BertL, Jon G4LJW
Peter, thanks for your continued maintenance and running of the TM Image Library thumbs
1 member likes this: OZ 4/4
Thank you again for your support!
Yes Thank you
1980 +8 Blue
And a few others
Stephen
+1
Robbie
2021 Plus Four -- Helga
211-WX-1433
An excellent facility, thanks Peter! smile
The facility to view and or upload pics is for me a fundamental aspect of enjoyment of TM. Thanks for putting the time in to keep the facility updated, and us informed Peter.
I do seem to have posted quite a few pics on the Image Library, perhaps I should cull most of them to save space..?
+1
Costock, UK
Disco 5
