6 members (Alan Patterson, DJC, DaveW, Sheridan, Mike D, JohnHarris), 291 guests, and 66 robots.
+8Rich 64
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,880
Posts837,777
#800533 17/05/24 02:18 PM
My 1980 +8 with a John Eales 4L HS6 SU Carbs with uprated kenlowe fan, oil cooler, ali rad, big bore manifolds (unwrapped) is struggling to restart in warm/hot weather. Replaced fuel pump with a new facet pump, no improvement. Have covered 250k miles all over Europe, always use E5 and have never had this problem until this year. On restart you can hear the pump repriming/building up pressure and the car will restart in around a minute.
Anyone having a similar problem? Any thoughts?
1980 +8 Blue
And a few others
Stephen
Can it be the ballast resistor?
Are the fuel lines to carbs at all warm immediately before starting issues Stephen? If so then use of silvered foam wrap may help. Fuel feed to distribution rail on my Roadster is treated with this.
...... coil/capacitor?
David Byrne
Pull off the air cleaner whilst you have the same hot conditions and squirt a bit of petrol directly into the carbs, if it fires easily then yes vaporisation is highly likely
Although no comparison on BHP my tiny F Super was a pita when hot restart because the pipes (solid copper) and pump are close to the manifolds - I bought some glass fibre pipe sleeve coated with silver wrap from Demon Tweeks
