2 members (JohnHarris, TalkMorgan), 345 guests, and 96 robots.
Topics49,848
Posts837,406
DazMog, The Impaler, tlchzj79
GrumpyPa #800726 21/05/24 10:45 AM
Fuel inj, the lift is a MSL3 from Garage Equipment Group (GEG) Bromborough, Wirral, CH62 3QL.
Hope this helps, if you want any more info please get in touch.
David Byrne
GrumpyPa #800728 21/05/24 10:49 AM
P.S. the width of the morgan chassis is less than the width of the lift platform so you have to use some packing, I chose 4" square box section it also has the added benefit of extra height .
David Byrne
GrumpyPa #800731 21/05/24 11:16 AM
For a more budget friendly option I use one of these, except mine is not the low profile. It doesn't lift above head height, but when fully raised and tilted the bumpers are close to or at chin height. As with the others, a smooth surface for movement is necessary.
https://cjautosheywood.co.uk/product/low-profile-2-ton-mini-car-lift-cl33/
06 Saab 93
B3MOG #800736 21/05/24 11:28 AM
David Byrne
Wow that's a neat lift but nearly double what I paid for Automotech one which was £1500 all in and delivered (still only £1350 + VAT now). I did have to add stainless plates to my garage floor for the wheeled part of scissor to run on though to save wear on concrete.
GrumpyPa #800751 21/05/24 04:39 PM
Thanks for all your observations. I need to give it a bit more thought. As I only have a small garage it's also a question of storage. The Automotech one looks good but I would find it difficult to find somewhere for the trolley. One thing I am not clear on. Could I store the EZ under the Mog? I know it would be a trip hazard when the car isn't in the garage.
1956 Plus 4 4 seater
TBM #800764 21/05/24 07:53 PM
I'd love a lift, but it would need to be light enough to carry round the front of the house, and work on badly laid concrete. I think I'm going to have to stick with jacks and stands until I can get the drive properly concreted.
If it's possible try and incorporate a recess to house the lift, mine sits on a garage floor & needs thick plywood ramps down each side, eg RichardV6 has to use scaffold boards
Unfortunately any recess would be full of water and leaves within minutes!
Oops, forgot you were outside doh
GrumpyPa #800767 21/05/24 08:43 PM
The EZ Carlift is the best tool I bought 8 years ago, in almost constant use with my 3 Morgans as it is so easy to use and as Nic said gives access from all sides. I use it for all sorts of things besides the Morgans, no messing about with hydraulics or remote lift machinery. As it is easily assembled and disassembled I have taken it to other friends garages to help them, the castors allow me to easily move it about the garage to go under the other cars and store up against the wall out of the way.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
GrumpyPa #800780 22/05/24 07:48 AM
The EZ-Lift come with 2 brackets that can be used to hang the lift on a wall. You can see mine on the right hand side of the garage in the photo below
I have a small block and tackle fastened to the garage roof to lift it up and down with.
If you need better photo's - please just ask thumbs
Ian S
2019 Sports Green Plus 4
2025 Hyper Blue Mercedes 180 CLA
GrumpyPa #800782 22/05/24 08:06 AM
Just popped in the garage to take a couple of pics that may help envisage how mt lift is stored
Hope they help smile
Ian S
GrumpyPa #800786 22/05/24 08:52 AM
That's really helpful, thanks. It gives a better idea of the kit rather than the publicity photos. I had thought it would store under the car but maybe that's not the best idea.
