3 members (bmgermany, RichardV6, Mick Annick), 220 guests, and 27 robots.
+8Rich 99
John V6 57
Topics49,908
Posts838,124
Yep that's correct MMC in the handbook for classics quote for copper cored plugs 1.25-1.35mm. The original thought with iridium was to be able to carry an increased gap size as the smaller precision electrode allowed the gap to be jumped more accurately, it could leave the electrode more easily and from a predictable point. The plug design allowed for a fatter spark to develop and therefore ignition was more efficient but as has now become known this brings problems to even iridium electrodes and coils and coil packs. This resulted in a period of several years to resolve and cost Ford a fair bit in coil packs. So now all that you really gain from iridium plugs is longevity ie. they are capable of 100,000mls in theory but cost for cost, four or five sets of copper core standard plugs would equate to perhaps a better option as plugs can fail inexplicably and with the copper option you will have arguably tip top plugs fitted all the time. If you race or trial your car then iridium will tolerate higher temperatures and may prevent early failure so perhaps a better choice there but when I change next time, probably through plug body corrosion, I too will return to copper cored options as I really cannot feel any difference between the two options, that is except for cost!
For info 33thou in the S.I. system is 0.85 mm so a setting of 0.8 to 0.9 should be fine.
If I fit Iridium plugs my preferred choice is NGK, second Ford...BUT I always buy from a reputable supplier and NEVER off t'web
Caveat Emptor !
Online NoMood
Article here on swapping OE Motorcraft Iridium plugs for NGK Jon. Bought mine online from the Green Spark Plug company. Also available here.
Thanks Richard,
My OE Motorcraft Iridium plugs in the last Roadster lasted so well that I probably won't touch this one until 2026 innocent
Online NoMood
Ironic that the OE Motorcraft are probably NGK anyway since they have their number equivalent stamped on the main body.
Originally Posted by Hamwich
My 4/4 (tuned Ecotec VVTi with MBE ECU) has been getting more and more reluctant to start over the last couple of thousand miles. Nothing too terrible, it runs fine once it's going, but it's worse when it's been sat for a while, sometimes taking a good lot of cranking to fire. .....
You're mentioning difficulty in starting. My experince with engine management systems is that in the cranking phase (before the engine reaches running/idle phase) only few sensors are relevant. This is the crankshaft, camshaft, voltage level and water temp (of course you need spark and fuelpressure). Anything else is most likely ignored until the engine runs. Cranking phase is when the engine has less than 300 rpm. Voltage level is important because injection time varies significantly with lower voltages, which obvioulsy the case during cranking and the ECU compensates that.
