0 members (),
297
70
Topics49,870
Posts837,668
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
In that long list you did not mention throttle position sensor...
Posts: 1,738 Likes: 56
Posts: 1,738 Likes: 56 |
Idle Air Control (IAC) valve sticky? Worth taking it out and cleaning it I reckon. Also worth slipping out the Crank Position Sensor and cleaning / inspecting for damage too. If Oxygen/Lambda sensors were faulty you would most likely get an error code.
Andy
Posts: 8,684 Likes: 493
Posts: 8,684 Likes: 493 |
Do those little rectifiers still fail, I remember quite a few owners of early 5 speeders having problems ?
Posts: 62 |
These failures were more than likely down to poor earth connections although the Harley unit is said to be more robust
Posts: 1,370 Likes: 11
Posts: 1,370 Likes: 11 |
The H-D unit is FAR more robust. The stock rectifier, in the biker community, became known as 'delicate' or just a POS. It didn't really matter about the ground. My own replacement H-D rectifier, probably made in China, is still going strong.
