10 members (Willowgreen320, Hamwich, Alan Patterson, MATTMOG, sewin, RobS, Rog, High Hamster, stumog, Morganmike),
273
42
Posts837,969
Posts: 875 Likes: 157
Posts: 875 Likes: 157 |
As a previous owner of a 2012 MTW, I have always been accustomed to the squealing noises generated by the 3-wheel drive belt. However, I was surprised to find that this transmission still sounds just as good on the new MS3. I took my MS3 to a friend this weekend, he loved the test, however he was shocked at the noise level of the transmission. Is this bird singing noise normal?  Can it be reduced?
Lille - France Sold : MTW 2012, 4-4 Sport 2010, Roadster V6 2008, Super3 2024 Plus Four 2024
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Cram it full of birdseed?
Is it the same Mazda transmission they now use?
it's the same combined Mazda gearbox / bevel box / final belt drive
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
it's the same combined Mazda gearbox / bevel box / final belt drive  The bevel box on the Super 3 whilst similar to that of the M3W is from a different supplier.
I have several problems with the MS3, I'm going to drop it off at Morgan Brussel, I'll ask them to check why it's making so much noise...  It seems that a chain transmission makes less noise, but I don't know if it is installed systematically or not...?
I dropped off my MS3 last week at Morgan Brussel. They confirm to me that the belt transmission will always make a lot of noise, that they have a special grease which helps reduce the noise, but that it is temporary...  that's why they recommend chain transmission, it's a free option when you order a new MS3, it pays when you have a belt MS3 that you want to convert to a chain...  But they confirm that the difference is enormous!  However you have to pay...again....
The Morgan Belgium mechanic uses this grease for the belt. This eliminates 95% of noise, but it must be added approximately every 600/700km : ![[Linked Image]](https://zupimages.net/up/24/27/yp0p.jpg)
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
The Morgan Belgium mechanic uses this grease for the belt. This eliminates 95% of noise, but it must be added approximately every 600/700km : Never thought about lubricating the drive belt - is it silicone, PTFE, lithium grease or something else?
Posts: 571 Likes: 90
Posts: 571 Likes: 90 |
Back in the 70's I was assigned to an exploration vessel that used multiple Detroit Diesels driving Chicargo Pneumatic PB44 compressors to generate air at 2000 PSI. The compressors were driven by multi V belts. At that time part of the routine maintenance was to spray the belts with belt dressing that improved both the grip, reduced the noise and extended the belts life. Belt dressing spray is still easily available and is suitable for both V belts and Cogged belts. It will quieten the belt drive down.. However, pls note, we used the belt dressing in a semi clean environment within the vessel. Not sure how the dressing would impact the belt wear if it was also subjected to road grime. If you Google Belt Dressing sprays there are multiple choices. The posted photo is a belt dressing spray... If you want to go this route check each products suitability.
