Topics49,912
Posts838,163
Posts: 72 Likes: 6
Posts: 72 Likes: 6 |
Hi everyone
Some of the LM62 owners will be aware already but there are a couple of instances of clutch failures on manual Plus Fours. Friend of mine ended up buying the grey plus four with the white leather (see other thread) and only after a few hundred miles the clutch pedal went long. One of the LM62 (CX) owners has also suffered a clutch failure - looks like the same part - the rod (or piston?) that is attached to the clutch pedal and passes through the bulkhead.
I have a long road trip planned and my clutch is already squeaking - feeeling a bit nervous about that so I thought maybe I'd buy the part to carry. It seems the LHD version may be Valeio part 2113615.
Question: - has anyone else had a failure? If so which part - does anyone know the part number for RHD cars, I can't find it - would a roadside replacement also require the clutch to be adjusted or is it essentially a straigh and simple swap of a mechanical arm
So many questions - sorry!
Thanks in advance for any input - I'm going to try to get the car looked at before I go away but planning for the worst here
Posts: 33 Likes: 9
Posts: 33 Likes: 9 |
Had the clutch master cylinder replaced after it was squeaking. (Mar '22 car) it used to squeak after around 200 miles of driving. sounded like an old wooden door closing . mileage was around the 13000 mile mark when it started. replaced around 15000. car now nearly 21k & been ok.
Posts: 72 Likes: 6
Thanks for the info. Yep mine is squeaking like mad. I've booked it in for a precautionary look .... if there is anything to feedback I'll drop it here for general info
Posts: 72 Likes: 6
Just an update for anyone interested. My friends Plus Four has been diagnosed with a leaking master cylinder and that is being replaced under warranty. Also FYI without asking they are replacing the petrol cap again under warranty.
Posts: 72 Likes: 6
Hi - for completness update on mine. Clutch was squeaking like mad but some lube on the springs by the dealer sorted it. I did ask for the replacement petrol cap but apparently the LM62 is slightly different to the PLus Four so they couldn't supply one at this time.
