3 members (Ian Wegg, hillclimber, TBM), 198 guests, and 86 robots.
+8Rich 80
DaveW 51
Topics49,866
Posts837,595
Once it starts Drive it that's what it's for.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
Mine did that. Messed about half a day couldn’t get it to go. Tried spare key and bingo. Away it went. No problems since
Simon
2002 4/4
2021 Audi A1 sport
Thanks Gents, I have anew fuse blade tester. ordered two new relays and a new cut off switch, tested the pump fuse today green light stayed on the tester when put across the blades so tomorrow I will go through the lot, I will give an update when the rest of the bits arive.
Tried the new relays still no activity via the pump, Just wondered if ou can fit a seperate switch to the pump so enable you to turn the pump on before turning the engine over.
U
TM Photographer of 2008
U
This thread may provide a solution.
Ken
I did that, no good, the problem was the key
Simon
2002 4/4
2021 Audi A1 sport
