SORN
New
Topics48,375
Posts813,508
Members9,215
Posts: 2,041 Likes: 71
Posts: 2,041 Likes: 71 |
Once it starts Drive it that's what it's for.
Bruce 1964 4/4 Series V Comp (Megan) 1994 +8 (Maurice) 2013 M3W (Olga)
Posts: 511 Likes: 1
Posts: 511 Likes: 1 |
Mine did that. Messed about half a day couldn’t get it to go. Tried spare key and bingo. Away it went. No problems since
Simon 2002 4/4 1936 Austin 12 light 4 Ascot saloon 2023 AMG Mercedes C300e estate 2021 Audi A1 sport
Posts: 12 |
Thanks Gents, I have anew fuse blade tester. ordered two new relays and a new cut off switch, tested the pump fuse today green light stayed on the tester when put across the blades so tomorrow I will go through the lot, I will give an update when the rest of the bits arive.
Posts: 12 |
Tried the new relays still no activity via the pump, Just wondered if ou can fit a seperate switch to the pump so enable you to turn the pump on before turning the engine over.
Posts: 837 Likes: 1
TM Photographer of 2008 Talk Morgan Regular
Posts: 837 Likes: 1 |
This thread may provide a solution.
Ken
Posts: 511 Likes: 1
Tried the new relays still no activity via the pump, Just wondered if ou can fit a seperate switch to the pump so enable you to turn the pump on before turning the engine over. I did that, no good, the problem was the key
