8 members (Strathaven, Deejay, BLUE+4, Simon, John V6, B3MOG, B&C Morgan, nick w),
194
51
Topics49,859
Posts837,498
Posts: 2,222 Likes: 182
Posts: 2,222 Likes: 182 |
Once it starts Drive it that's what it's for.
Posts: 521 Likes: 2
Posts: 521 Likes: 2 |
Mine did that. Messed about half a day couldn’t get it to go. Tried spare key and bingo. Away it went. No problems since
Simon 2002 4/4 1936 Austin 12 light 4 Ascot saloon 2023 AMG Mercedes C300e estate 2021 Audi A1 sport
Posts: 16 |
Thanks Gents, I have anew fuse blade tester. ordered two new relays and a new cut off switch, tested the pump fuse today green light stayed on the tester when put across the blades so tomorrow I will go through the lot, I will give an update when the rest of the bits arive.
Posts: 16 |
Tried the new relays still no activity via the pump, Just wondered if ou can fit a seperate switch to the pump so enable you to turn the pump on before turning the engine over.
Posts: 849 Likes: 2
TM Photographer of 2008 Talk Morgan Regular
Posts: 849 Likes: 2 |
This thread may provide a solution.
Ken
Posts: 521 Likes: 2
Tried the new relays still no activity via the pump, Just wondered if ou can fit a seperate switch to the pump so enable you to turn the pump on before turning the engine over. I did that, no good, the problem was the key
