7 members (RobC, JMcL, TalkMorgan, RedThree, Liam1961, Rudolf, TBM), 285 guests, and 86 robots.
Sagging Hood
Topics49,859
Posts837,468
#802838 03/07/24 10:30 AM
MR11MOG Offline OP
The short hood release cable at the release handle has broken on my easy up hood ,anyone any advice on fitting a new one.
I have a replacement due this week .
Peter.
Aero plus8 50th Anniversary.
MR11MOG #802902 04/07/24 07:34 AM
It's a dreadful system Peter, so I decided to replace it with some traditional hood catches.
In the above video I was still using one of the original locking pins and releasing it with a run of paracord to replace the awful cable system, laterly I removed that last pin too and the paracord, I now just use the two Triumph Herald hood catches.
The only minor disadvantage is you need to be sat in the car to release my Herald catches, but it's really no inconvenience at all. I just reach behind and the hood is released in a second, when putting the hood up I fit the two header rail catches first as normal and then close the Herald catches while sitting in the car to tension the hood.
The system is super simple and looks period correct, but above all it replaces the dreadful Morgan cable operated bonnet release pin system with something that's completely reliable and effective.
MR11MOG #802921 04/07/24 11:57 AM
MR11MOG Offline OP
Now that is a super simple solution,..well done.
Peter.
MR11MOG #802927 04/07/24 04:52 PM
Brilliant solution.
cheers
Bud
4/4 - Stanley
Bud
4/4 "Stanley"
MR11MOG #802930 04/07/24 05:45 PM
Nice. It's the same principle as the Simmonds hood conversion, but your catches are much prettier!
MR11MOG #802938 04/07/24 07:58 PM
Till you put in luggage. Which isn't often
Hamwich #802950 04/07/24 09:33 PM
Just try sourcing a pair at a reasonable price!
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
MR11MOG #802954 04/07/24 10:14 PM
Agreed the mog solution is pants vs the old Simmonds hood .
MR11MOG #802959 04/07/24 11:56 PM
The Herald hood catches were £55 for the set, money well spent in my opinion, I do use the parcel shelf for luggage storage and quite regularly too but to date accessing the catches has never proved to be an issue.
In theory the Morgan cable operated MGB bonnet pin system is more convenient, indeed when it's working correctly it is, however I found it to be very unreliable and frustrating to use so I replaced it with something simpler.
The Herald catches are staying, and I definitely won't be going back to Morgan's idea!
MR11MOG #802960 05/07/24 12:09 AM
Where did you source the Herald catches from?
Thanks
Bud
Bud
4/4 "Stanley"
