7 members (High Hamster, Sir Percival, CRL, JohnHarris, Craig Jezz, gmcn, JoeSpeetjens),
205
109
Topics49,872
Posts837,693
Posts: 1,245 Likes: 30
Posts: 1,245 Likes: 30 |
Glad this issue has been raised again. My 2011 4/4 has black piping, which feels like rubber. I have used ACF50 since new, without problems. But recently on the drivers side in the door area a 5 inch section has become loose. The piping still feels ok, not soft or sticky. If we were not discussing the lube, I would say that there had been some movement of the wing away from the body, so not “gripping” the piping, in that area. The piping pushes back quite easily, but gradually works it way out in a couple of weeks. Not all the way out more of a slight bulge. I thought at some point I’ll have to have the exhaust off & see if the wing mounts are still tight. Any suggestions welcome.
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
Craig Jezz
Craig, yes that is like mine but so far in only 1 section. How did you fix it? Thanks
Craig, yes that is like mine but so far in only 1 section. How did you fix it? Thanks From memory I loosened a few bolts under the running boards and pulled the piping & re tightened. It helped a little, but I found by cutting out the lubricating altogether the rubber hardened & it self cured. The service guy at Williams did say that they don’t lubricate the piping for this reason. Maybe I over done it !
Craig Jezz
Posts: 8,684 Likes: 493
Posts: 8,684 Likes: 493 |
Glad this issue has been raised again. My 2011 4/4 has black piping, which feels like rubber. I have used ACF50 since new, without problems. But recently on the drivers side in the door area a 5 inch section has become loose. The piping still feels ok, not soft or sticky. If we were not discussing the lube, I would say that there had been some movement of the wing away from the body, so not “gripping” the piping, in that area. The piping pushes back quite easily, but gradually works it way out in a couple of weeks. Not all the way out more of a slight bulge. I thought at some point I’ll have to have the exhaust off & see if the wing mounts are still tight. Any suggestions welcome. The factory appear to tack the piping in place with staples (I don't think stainless) so perhaps some have gradually corroded or the frame movement has elongated the tiny holes allowing the piping to move about. A full and final cure may mean 'wing off' or try masking the paintwork, ease the piping out a bit, de-grease and apply clear Uhu to the flange and push back in, then use something like a strip of blu tack to hold it in place for at least a day
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
My car is 11 years old with maroon piping, I have never treated it and it's fine.
Posts: 101 |
Pardon my ignorance here but why would you go anywhere near the piping on cars with aluminium body panels? I have a 2002 +8 and use ACF50 to great effect on the shiny bits but have never felt the need to apply it to paintwork or piping. Especially so if you have paint protection film.
Les Ellis Putting the Plus 8 burble into the Cheshire countryside. 2002 +8 2018 Audi S1
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
I think that the 3 in 1 oil recommendation annually is for two reasons. It will inhibit rust in the staples, and it will create an element of lubrication so that the chassis twist will allow easier movement between the wings and the body tub. Like anything else, we have a choice and there will be consequences either way, but it will never be exact because both mileage covered, and the amount of wet weather encountered will affect the outcome.
If the movement chafes the paint, the aluminium will start to corrode.
1 member likes this:
CooperMan |
Posts: 1,615 Likes: 1
Posts: 1,615 Likes: 1 |
Ok. Tips for removing the wings, please?
SFG 2012 4/4 Sport
Posts: 12,263 Likes: 320
Posts: 12,263 Likes: 320 |
Ok. Tips for removing the wings, please? A job best avoided if possible, depending on how your wings were fixed on. These days they use threaded inserts in the wood and it's all a lot easier but I don't know if they were doing that in 2012. When I removed my wings I had to grind off the heads off all the bolts and then re-drill holes in the arches and under the rocker panels so I could put inserts in. OK for me as I was fittinng new wings so they had to be drilled anyway, but I wouldn't think you'd want to do that if you were refitting the existing wings.
