Hi
Pretty soon I’m going to be replacing the rear springs.
As MMC thought it would be a good idea to fit the in tank pump/sender directly under one of the rear frame cross spars & my sender hasn’t been working for many years, I thought I’d use this opportunity to change the pump/sender out.
Does anyone know who the manufacturer- part number is ? As the engine is the 3.9 EFI I suspect it may be a Landrover bit ( but you can never tell with the MMC)
Any help is greatly appreciated
