Topics49,868
Posts837,640
Posts: 1,615 Likes: 1
Posts: 1,615 Likes: 1 |
I found a nut in my driver’s side footwell. Does anyone have a photo of the chassis earth behind the dash on. 2012 4/4 please?
SFG 2012 4/4 Sport
Posts: 8,683 Likes: 413
Posts: 8,683 Likes: 413 |
What size was the nut SFG?
Posts: 27,816 Likes: 749
Posts: 27,816 Likes: 749 |
The earth is on the heater box top lhs (UK passenger side).
![[Linked Image]](https://www.tm-img.com/images/2024/07/29/IMG_2329.jpeg) Thanks for responses. Similar to this, which also dad fallen off(I’m not home at the moment) If the earth point is on the LHS, the happily it’s probably from the earthing point
SFG 2012 4/4 Sport
Posts: 1,873 Likes: 174
Posts: 1,873 Likes: 174 |
![[Linked Image]](https://www.tm-img.com/images/2024/07/29/IMG_2329.jpeg) Thanks for responses. Similar to this, which also dad fallen off(I’m not home at the moment) If the earth point is on the LHS, the happily it’s probably from the earthing point At least, you have a real Morgan....!
Ruut Bianchi Morgan PlusFour 2023 Bentley Midnight Emerald Morgan 4/4 4-seater 1990 Royal Ivory
That's probably a 6mm nut SFG. The two grounding eyelets behind dash are also 6mm. However if the nut holding the two in place had come undone I'm pretty sure you would be seeing intermittent electrical issues developing before complete failures. It's not unknown for a fixing lost during assembly of car to simply drop into the footwells over time. I've certainly found the odd washer appearing.
I’m on a rally on Sunday so it would be inconvenient. I’ll get some miles on it beforehand
SFG 2012 4/4 Sport
Posts: 8,682 Likes: 493
Posts: 8,682 Likes: 493 |
Wriggle into the footwell, head up under the dash - find a black wire and hopefully follow it's path until you find the earthing point
SFG 2012 4/4 Sport
If it came from the earth I agree with Richard you would see many issues.
