0 members (),
292
50
Posts837,277
Posts: 1,004 Likes: 31
Posts: 1,004 Likes: 31 |
I can testify to that, everytime he overtakes me (Ruut is much faster of course!), he uses that button, and what a lovely sound…
2025 Plus Six - 1909 2009 Roadster 1983 4/4 4str Board member Morgan Sports Car Club Holland ('21)
Posts: 8,657 Likes: 407
Posts: 8,657 Likes: 407 |
Here is a well spec'd one seen yesterday. Dynamic handling pack, Sports exhaust, Brembo front calipers, Black pack, Spare wheel, LED light pack, Sennheiser audio, soft grained leather, to name just a few. Finished in metallic marble white but asking nearly £93,000! ![[Linked Image]](https://i.imgur.com/SVA3SR0.jpg) ![[Linked Image]](https://i.imgur.com/6X3N7aq.jpg) Dread to think of replacement cost of the 8 inch headlamps though. ![[Linked Image]](https://i.imgur.com/4bp32YP.jpg) Very clean rear with the reversing light barely visible but no doubt very bright. Number plate illumination looks odd from this angle though.
Posts: 2,432 Likes: 66
Posts: 2,432 Likes: 66 |
And missing a couple of cylinders....
The lighting component count is certainly reduced and consequently some build time. Debatable what raw component savings there are, but likely some. The missing cylinders can be made up by KH with PCM mapping (which includes auto box, halving change times whilst softening down shifts) and CAT upgrade once warranty has expired, if you can wait the three years now offered.
Posts: 1,981 Likes: 103
Posts: 1,981 Likes: 103 |
Debatable what raw component savings there are, but likely some. So take a couple of minutes to apply some tyre dressing (not the wet look stuff, ugh) to the rather scruffy looking tyrewall on the spare.
Peter 2009 3-litre Roadster "Ivor", royal ivory / green
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
Here is a well spec'd one seen yesterday. Dynamic handling pack, Sports exhaust, Brembo front calipers, Black pack, Spare wheel, LED light pack, Sennheiser audio, soft grained leather, to name just a few. Finished in metallic marble white but asking nearly £93,000! ![[Linked Image]](https://i.imgur.com/4bp32YP.jpg) Very clean rear with the reversing light barely visible but no doubt very bright. Number plate illumination looks odd from this angle though.Would look much better shining 'top down' than 'bottom up' (I think some of the Trad ARP4's had a better version ?)
Posts: 3,439 Likes: 7
Goodwood Drifter Talk Morgan Addict
Posts: 3,439 Likes: 7 |
Hi Every day is a learning day - why should someone not pay for a sports exhaust on a turbo-engined car? I'm curious. This is not a test question  Genuine question Thanks Neil wel the sound is muted by the exhaust-fumes going back to the turbo you can make it a bit louder, almost never any 'better sounding' I payed a lot of money on an Akrapovic on my 1Mcoupé and it sounded worse, louder but worse on my 2022 PlusFour I have the sport exhaust and that creates those horrible pops&bangs  I placed inox exhaust on a 3litr V6 roadster: that was amazing, 100x better than OEM!! broke the exhaust on one side of my M3W: deafening :lolz:
Steven sold: M3W, Aeromax,V6, 4/4 4seater now: +fourLM62
Posts: 6,666 Likes: 433
Posts: 6,666 Likes: 433 |
Surely the prime poiint of a 'sports' exhaust is to improve gasflow and therefore make the car peform better? If it's just a 'louder' exhaust you want, then there are cheaper options than a full sports system.
1 member likes this:
Jon G4LJW |
Posts: 12 |
Yes the exhaust flows better, sounds much better under full throttle, if the car is auto you can get the same level of noise in normal Sport mode as you can in Sport + Mode in a manual car but without the need for the pops and bangs that not all like. Plus... in normal driving mode cruising along the Sports exhaust is quieter with less drone than the standard exhaust due the valves in the system.
Posts: 7,435 Likes: 122
Posts: 7,435 Likes: 122 |
![[Linked Image]](https://i.imgur.com/6X3N7aq.jpg) Dread to think of replacement cost of the 8 inch headlamps though. Not just the replacement cost, but also the looks, as has often been mentioned here. To be fair, I'd have to see it in real life, not just in photos. But in the photo it looks like a mismatched headlight has been temporarily tacked on with three strips of light grey duct tape.
