3 members (RichardV6, Hamwich, TeddyAds), 279 guests, and 49 robots.
+8Rich 92
Posts837,278
Rich #806289 26/08/24 08:37 AM
Rich Offline OP
Thanks Chris99 for the info about basic & advanced. I am going to take your advice and check fuel pressures before I attempt to mess with ProTune. The more I read about ProTune the more I feel that it is best left to someone who is familiar and experienced with it. Fuel pressure I can do with confidence.
2014 3 wheeler
1987 Plus 8
2000 Harley Wideglide
1970 Corvette
1951 Vincent Black Shadow
Rich #807278 08/09/24 10:52 AM
Rich the check engine light is not necessarily cause for immediate action. My 2013 car threw up this warning, the dealer tried various fixes swapping out various bits on the engine. I collected it with light out & set of home but the light came on again within 20 miles. I drove it for around 2 months with warning on till they could look at it again. A new updated ECU solved it. I did not notice any detrimental effect with the warning on either performance of fuel consumption. Its a yellow light not red so not to panic.
Rich #807705 14/09/24 10:43 AM
my check engine light has been on for 22k miles
Rodger
2004 Plus 8 (wife's)
Rich #808503 26/09/24 09:13 PM
Where is the ECU located, please?
Rich #808507 27/09/24 07:01 AM
Online NoMood
Shown below as part #13 so underneath relays. It houses the diagnostic port you have been discussing above.
Note your 2014 car would not have had the flasher relay as that was incorporated in TSM unit on later models.
Rich #808737 02/10/24 01:43 PM
Rich Offline OP
Has anyone had experience with this system of using the check engine light to find or clear faults?
CHECK ENGINE LAMP DIAGNOSTICS
The S&S Cycle ECM has a feature which can report engine faults by flashing a code via the Check Engine lamp on the vehicle.
NOTE: If you have set your vehicle to use the check engine lamp as a shift-light, this function will be disabled.
The procedures to activate and read the Check Engine Lamp are as follows:
Turn the ignition switch to the on position for three seconds (one second pause after the fuel pump stops) and then switch back to the OFF position for three seconds. Repeat this procedure one more time and then turn the ignition to the on position and wait for eight seconds for the engine lamp to start flashing.
2. The transmission of a code is always preceded by a series of rapid flashes (about 3 per second). This "intermission" is followed by a 2 second pause in which the lamp is off. The lamp will then flash one or more times to indicate the first digit of the trouble code. The length of time the lamp is illuminated and the length of time in which it is off are about 1 second in duration. The number of times the lamp flashes indicates the first digit of the trouble code.
3. Following the transmission of the first digit, there is another 2-second pause in which the lamp is off. The lamp will then flash one or more times to indicate the second digit of the trouble code. The number of times the lamp flashes indicates the second number of the trouble code.
4. Following the transmission of the second digit, there is a 2-second pause in which the lamp is turned off. After the pause comes an "intermission", followed by transmission of the next recorded trouble code. All subsequent codes are sent in the same manner, each separated from the next years "intermission". Once the trouble codes have been sent, the data string is repeated. See the Check Engine Lamp - Fault Flashing Codes for a list of the trouble codes supported.
5. Turn the Ignition Key switch to OFF. Wait 10 seconds for the ECM relay to click. Vehicle can now be started normally.
2014 3 wheeler
1987 Plus 8
1970 Corvette
Rich #808739 02/10/24 01:57 PM
Rich Offline OP
The left column below is the "Check Engine Lamp Flash Code"
The second column is the standard "Speedometer Diagnostic Code"
The third column is the "Fault Condition”
11 P0122 Throttle Position Sensor Low/Short Circuit
11 P0123 Throttle Position Sensor High/Open Circuit
12 P0105 Barometric Pressure Sensor Malfunction
12 P0108 MAP/Baro Sensor Low/Open Circuit
14 P0117 Engine Temperature Sensor Low/Short Circuit
14 P0118 Engine Temperature Sensor High/Open Circuit
15 P0113 Intake Air Temperature High/OpenCircuit
15 P0112 Intake Air Temperature Low/Short Circuit
16 P0562 System Voltage (Battery)Low
16 P0563 System Voltage (Battery) High
23 P0261 Front Injector Open Circuit
23 P0262 Front Injector Short Circuit
32 P0264 Rear Injector Open/Low
32 P0265 Rear Injector Short/High
34 P0505 Stepper Motor Malfunction
52 P0604 ECM RAM Error
53 P0605 ECM Flash Error
54 P0603 ECM EEPROM Error
55 P0606 Microprocessor Malfunction (ECM Processor)
P0217 Overheat Protection Stage 1
P0217 Overheat Protection Stage 2
P0217 Overheat Protection Stage 3
71 P0327 Knock Sensor Circuit Low Inout
72 P0328 Knock Sensor Circuit High Input
P0132 Front 02 Sensor High Voltage
P0134 Front 02 Sensor Open/Not Responding
P0170 Front Adaptive Maxed Out
P0152 Rear 02 Sensor High Voltage
P0154 Rear 02 Sensor Open/Not Responding
P0173 Rear Adaptive Maxed Out
2014 3 wheeler
1987 Plus 8
1970 Corvette
Rich #808775 02/10/24 10:32 PM
Yes, I've tried it some years ago and it didn't work on the Morgan. The only way to access the fault codes is with Protune.
Red Leader drive
1 member likes this: Stevo666
Rich #809087 08/10/24 12:44 PM
Dtc : Check errors
Options on the left above screen
Adaptative max limit : delete errors
Dtc delete errors
Normally engine light is delete
