Well The way I was shown by Dave Randall on my first short door 4/4 was put your inboard hand on the transmission tunnel, sliding your inboard leg in as you slide down being supported by your inboard arm compressing/dropping/ bending downwards and then bring your outboard leg in before you are fully seated. Its the reverse operation using your inboard arm as the rising lever on the transmission tunnel to lift you out All your weight is taken on your left arm and the transmission tunnel.
22 Plus Four KIMI
12 Plus 4 Sport OZZY
08 Roadster FELIX
06 4/4 70th LOKI
77 4/4 SEAMUS
85 4/4 MOLLY
