Morgan Aero 8
2 members (Soleng, Plus Four Guy), 282 guests, and 42 robots.
+8Rich 97
Luddite 54
Topics49,904
Posts838,088
KlausK Offline OP
Hello everybody,
can someone helt me to find the place where I can find the chassis no.?
After 1h searching we only found the type plate in mounted in the engine bay right hand side near the front window.
Thanks for your help and have a great Sunday,
Klaus
Hello Klaus welcome.
The chassis no. can be found on the chassis beam under the seat.
With my 4/4 it was on the beam in front of the right seat.
At the +4 behind the right seat.
1990 4/4 1.6 Ford CVH Sold
2014 +4 2.0 Ford
2005 BMW Z4 2.2 6Cyl Sold
Originally Posted by KlausK
can someone tell me to find the place where I can find the chassis no.? Klaus
https://www.gomog.com/allmorgan/ChassisNumbers.html
KlausK Offline OP
Thanks for your help. So, in my car, there is a beam in front of the right seat.... I found nothing on it. To check the other beam underneath the seat, I have to demount the right seat, right?
Hi Klaus, welcome to TM!
You should be able to see the beam when you move the seat forward
You may have to scrape a bit of paint off to have a clear view.
I did it to make it easier to find on the MOT.
Dirk
1993 Morgan +4 (Connaught Green)
2009 Mini Cooper D
2024 Mercedes GLC
1994 Ford Motorhome
Hi Klaus
My memory is apparently not what it used to be.If it ever was. hide
When I went for a ride on Sunday, I saw that the chassis beam on the +4 is in front of the seat.
It's a galvanized chassis, very difficult to see the no.
You can use a light to create some shadow,
2014 +4 2.0 Ford
This post is on the Aero platform section ??
Smile, it confuses them
On my Aero S2 and Coupe there is a number on display along the top edge of the dash, readable through the windscreen? Is this what you are after ?
KlausK Offline OP
Thank you for all your help! I found the number in the area marked by Dirk! Brilliant smile
Oh sorry I just read the title, you are discussing one of the models previous to the Aero with that odd wood stuff? I assumed it was an "aero" Plus 8 given it was in the Aero section.
