7 members (IcePack, BLUE+4, Ruut Bianchi, Paulxj, JMcL, Burgundymog, Image),
251
Topics49,905
Posts838,100
Posts: 3 |
Hello everybody,
can someone helt me to find the place where I can find the chassis no.?
After 1h searching we only found the type plate in mounted in the engine bay right hand side near the front window.
Thanks for your help and have a great Sunday, Klaus
Posts: 280 Likes: 58
Posts: 280 Likes: 58 |
Hello Klaus welcome. The chassis no. can be found on the chassis beam under the seat. With my 4/4 it was on the beam in front of the right seat. At the +4 behind the right seat.
1990 4/4 1.6 Ford CVH Sold 2014 +4 2.0 Ford 2005 BMW Z4 2.2 6Cyl Sold
Posts: 3 |
Thanks for your help. So, in my car, there is a beam in front of the right seat.... I found nothing on it. To check the other beam underneath the seat, I have to demount the right seat, right?
Posts: 537 Likes: 28
Posts: 537 Likes: 28 |
Thanks for your help. So, in my car, there is a beam in front of the right seat.... I found nothing on it. To check the other beam underneath the seat, I have to demount the right seat, right? Hi Klaus, welcome to TM! You should be able to see the beam when you move the seat forward You may have to scrape a bit of paint off to have a clear view. I did it to make it easier to find on the MOT. ![[Linked Image]](https://live.staticflickr.com/65535/54049306442_448f178094_b.jpg)
Dirk
1993 Morgan +4 (Connaught Green) 2009 Mini Cooper D 2024 Mercedes GLC 1994 Ford Motorhome
Thanks for your help. So, in my car, there is a beam in front of the right seat.... I found nothing on it. To check the other beam underneath the seat, I have to demount the right seat, right? Hi Klaus My memory is apparently not what it used to be.If it ever was.  When I went for a ride on Sunday, I saw that the chassis beam on the +4 is in front of the seat. It's a galvanized chassis, very difficult to see the no. You can use a light to create some shadow,
Posts: 8,701 Likes: 501
Posts: 8,701 Likes: 501 |
This post is on the Aero platform section ??
Posts: 11,535 Likes: 321
Posts: 11,535 Likes: 321 |
On my Aero S2 and Coupe there is a number on display along the top edge of the dash, readable through the windscreen? Is this what you are after ?
Posts: 3 |
Thank you for all your help! I found the number in the area marked by Dirk! Brilliant
Oh sorry I just read the title, you are discussing one of the models previous to the Aero with that odd wood stuff? I assumed it was an "aero" Plus 8 given it was in the Aero section.
