Topics49,844
Posts837,366
Posts: 2,086 Likes: 70
Posts: 2,086 Likes: 70 |
Caroline, From your post I have assumed your fuses are as mine and not John’s piccie. This being the case then the relays will be behind the dash left of the steering column and a bit awkward to get to. Dash removal is best and not too difficult but your electrician might like to know about it if unfamiliar with Morgan’s, so here’s a link…. https://www.talkmorgan.com/ubbthreads.php/topics/701736/removing-refitting-dashboardIf wired correctly the first two from left are fan low and fan high. Best of luck The two relays for fan high and fan low are for the radiator cooling fan and not the heater fan which Caroline suggested as a cause.
