6 members (JMcL, Luddite, Franko, IcePack, jbk, Mogdavid), 329 guests, and 34 robots.
+8Rich 102
John V6 64
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,916
Posts838,221
MossyfromNZ
Years ago I had an XR3i that acted similarly.. Rough running, ticked over ok but when revved it ran like a box of spanners. It was the plug leads. New set and back to normal.
DaveW Offline OP
Thanks all. Well as I said it was running Ok when we got home.
Anyway, I cleaned the electrical plug to the throttle body and checked that it's a smooth action. In the electrical box on the bulkhead I've re-seated all fuses and relays. I will replace those relays. All the fuses needed shoving in half a mm, so that's a worthwhile check. My fuse diagrams have boxes A and B reversed, that's quite common on the GDI. The fuse listings for each box start top left, come down the left bank, then across to the right and up the right bank. Worth knowing.
I also re-seated the two main fuses.
Then I cleaned the MAF sensor. It starts and runs perfectly in the garage..................So we'll see what develops
1 member likes this: John V6
