8 members (gaston, Zach, KLASG, Soleng, JD44, Graham, G4FUJ, JohnHarris, Morganmike),
235
57
Posts837,265
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
Yes set to AGM and used in winter. I have done 4k in the car since July.
Posts: 8,655 Likes: 407
Posts: 8,655 Likes: 407 |
If you keep your battery on smart charger for extended periods without use suggest recycling it every three weeks or so so it runs briefly through full charge cycle. This will stir up the electrolyte on lead/acid batteries that otherwise could stratify and allow localised plate corrosion on areas of high acidity. Some of the smarter smart chargers do this automatically - check manual.
Richard, my CTEK on does the recycling but you know me even in winter I take the car out
Posts: 1,981 Likes: 103
Posts: 1,981 Likes: 103 |
Richard, my CTEK on does the recycling but you know me even in winter I take the car out Does anyone know of an aftermarket extension lead for CTEK's ? Mine suffers from becoming crisp and inflexibe in cold weather (ooh, matron).
Peter 2009 3-litre Roadster "Ivor", royal ivory / green
Posts: 2,084 Likes: 69
Posts: 2,084 Likes: 69 |
Richard, my CTEK on does the recycling but you know me even in winter I take the car out Does anyone know of an aftermarket extension lead for CTEK's ? Mine suffers from becoming crisp and inflexibe in cold weather (ooh, matron). Amazon: 2.5 m extension leads readily available.
Amazon: 2.5 m extension leads readily available. Thanks, I'll check those out.
New battery installed & all is well. No warnings to go to a Mog dealer etc. I replaced like for like i.e. a new AGM but I wonder why we need that with no stop start function.
Posts: 1,163 Likes: 354
Posts: 1,163 Likes: 354 |
First of all, good to hear that the problem has been fixed.
I also don't understand why it has to be an AMG battery. These are the characteristics if such a battery is to be used:
Start-stop systems, Higher power requirements, Longer service life, Safety and comfort features, Electric and hybrid vehicles
Doesn't really apply to a CX Morgan
Clemens
PlusFour Red Baron MY 2022
Posts: 2,432 Likes: 66
Posts: 2,432 Likes: 66 |
I don't think you need an Agm battery, but they do keep their charge a little bit longer. Em
Trouble is the bmw cars with this engine has the same. Maybe the OS module requires it. It would be interesting to know if any brave would has gone the cheaper route
