2 members (PaulV, Robbie), 267 guests, and 38 robots.
+8Rich 92
Topics49,837
Posts837,286
#811239 08/11/24 09:38 PM
MOG37 Offline OP
Need help - I'm assuming this is a Bevel Box oil feeder tube. I believe that's what it was sold as - and I think that I have seen a photo or two of someone's installation. Can someone please confirm if that's what this is? Also, please point me towards any existing photos of it installed. I presume it attaches into the filler hole and then is fed up behind the seats / seat belts?
24 Super 3
23 Super 3
21 M3W
15 M3W
05 V6 Roadster
68 MGB GT 3.9L V8
67 MM 1000 Tourer
It looks like a system that was intended to be permanently fixed and increase the oil capacity of the bevel box. I'd leave it off and run with the amount of oil it was designed for.
Red Leader drive
3 members like this: Bunny, planenut, Stevo666
It is the remote Oil Fill from MorganCustoms. I use it and it does work well. If you need detailed instructions for this easy modification I have the instructions in PDF.
2018 S&S 110th Beetleback
1934 MX4 Beetleback (in restoration)
1965 Corvette Coupe 327/350
1 member likes this: MOG37
MOG37 Offline OP
Yes, that is what I believe it is. I do not have any instructions and Emil's website is no longer functional. I would be very grateful if you could post or message me those instructions. Any photos of your install would be great as well!!
24 Super 3
23 Super 3
21 M3W
15 M3W
05 V6 Roadster
68 MGB GT 3.9L V8
67 MM 1000 Tourer
I have a similar line on my car that connects where the side breather once was. It is not to increase oil capacity, rather to eliminate the oil mist that came out of that breather. Also handy as a filler tube for the bi-annual fluid changes.
Late 2012 M3W
MOG37 Offline OP
Steve, thanks. Do you happen to have any pictures of the install? Did you access via the rear wheel cover, from underneath, and / or from the front, behind the seats?
24 Super 3
23 Super 3
21 M3W
15 M3W
05 V6 Roadster
68 MGB GT 3.9L V8
67 MM 1000 Tourer
I did find a couple of photos. I forgot I plugged the original side hole and tapped a new one on top. The 'oil' cap at the end of the hose is the original one that previously mounted on the side of the bevel box. The hose goes towards the left side of the car then up.
Late 2012 M3W
looks like that would be fairly easy to fabricate now that Emil is gone
Rodger
2004 Plus 8 (wife's)
